First bike and first winter storage - Questions
First bike and first winter storage Questions
Engine oil to be changed before storage or change it first thing before riding season.
What is the gas level when it says full tank to prevent water condensation , just to the top of tank neck or what ,some say 3/4 of a tank, then add fuel stabilizer ( Stabil ) run it for five minutes done.
Should it be on the concrete floor non heated garage , or on the wooden planks, or in the air on a jack. Temps fall to Min -5 to -20 Max here.
Battery tender on 24 /7 for five months (Dec -April).
No starting for few mts in these cold months .
Received 5,202 Likes
This is what I do
I change the oil in the spring
yes battery tender and no starting
full tank of gas and when I fill up I add the appropriate amount of Seafoam and ride it home to get it through the system
Not on concrete. if on the floor I put a piece of remnant linoleum flooring down and carpet remnants under the tires.
Received 6,045 Likes
Before storage;I change the motor oil, clean and wax bike, bike on battery tender, top off gas tank with a fuel stabilizer, check tire pressure, cover her up with a breathable m/c cover and place a desiccant product under the bike. I do not start the bike until spring.
Not always easy to do.
When I lived up north, I would put StaBil in the tank, ride to the gas station and fill it up, park it in a corner of the garage with a sheet over it.
Connected a battery tender every couple of weeks, and disconnect it as soon as green light comes on. I don`t leave any type of battery charger plugged in (I don`t trust them, that`s just me).
Received 4,497 Likes
Well.........
There are 100 answers to every question on this forum. If you don`t want to see the thread, just move on.
Nobody had any issues adding the 101st or 102nd answer...
