basic fluid check question
Old Feb 20, 2020 | 07:50 AM
hell hound's Avatar
hell hound
Default basic fluid check question
I am servicing a 2002 heritage for a good friend of mine that has been sick for a long time, he is now recovering and wants to get back on the bike
Ive done a full service and have basic question.
final engine oil check how to: on side stand or level
transmission check, sidestand or level, on edge of threads or screwed in
on the engine oil, I put in 2.5 qts
on transmission I put in 22 Oz
on primary I put in just under 1 qt
Old Feb 20, 2020 | 08:38 AM
o/d's Avatar
o/d
Oil check is with bike level and engine warm. This I am certain of.
Trans fluid is also level and just edge of threads. This I am only fairly certain of. Memory...
You're quantities added sound ok IIRC
Old Feb 20, 2020 | 09:14 AM
hell hound's Avatar
hell hound
cool thanks o/d
Old Feb 20, 2020 | 11:43 AM
hattitude's Avatar
hattitude
As mentioned, make sure to run a softail engine for a minute or two before checking the oil.... It is a dry sump oil system. When they sit for awhile, they will sometimes allow oil to leak past the oil pump, and into the sump... it will give a false oil level reading unless you start the engine and allow the scavenging side of the oil pump to clear the sump and pump all the oil back into the oil tank. If you should top off the oil tank, when there is oil in the sump of the engine, it won't be long after you start it that the oil dipstick will pop out and oil will come out the tank like a volcano.... don't ask how I learned this....
This is from the cheat sheet I made for my 2003 Heritage... info from the Owner's/Service manuals...
ENGINE OIL: 3.5 QTS. W/ FILTER
  • start w/ 2.5 qts and fill per dipstick
  • check w/ vehicle level
  • dipstick cap inserted into filler neck
  • oil plug, 1/4 hex, 14-21 ft-lb
TRANS OIL: 24 OZ
  • start w/ 20 oz and fill per dipstick
  • dipstick cap resting on threads
  • plug on bottom of case between shocks
  • plug, 1/4 hex, 14-21 ft-lb
  • dipstick cap, 3/8 hex, 25-75 in-lb
PRIMARY OIL: 26 OZ
  • Fill to bottom of clutch basket / level
  • drain plug, tighten until it projects .160-.180 in from bottom of case
  • inspection cover 84-108 in-lb
  • clutch cover 84-108 in-lb
  • clutch cover / 27 torx
Old Feb 20, 2020 | 02:14 PM
Naz's Avatar
Naz
Don't forget the blinker fluid. Revzilla has a special: https://www.revzilla.com/common-trea...-blinker-fluid
Old Feb 21, 2020 | 08:45 AM
hell hound's Avatar
hell hound
that is a pretty sweet cheat sheet
I ended up using almost 3 quarts of engine oil
Old Feb 21, 2020 | 09:31 AM
hattitude's Avatar
hattitude
That's where I usually end up too....
As far as the cheat sheet.... I have 3 Harleys... subtle differences between the three. I have the cheat sheets mounted inside a cabinet door, where I store fluids and filters.... when doing a service I can glance at the cheat sheet as a reminder, so I don't have to dig through the Service Manuals...
Old Feb 22, 2020 | 08:47 AM
cruzomatic's Avatar
cruzomatic
Great idea. I'll be doing that as well. Thanks for the tip/idea.
Old Feb 23, 2020 | 02:29 AM
HarleyViking's Avatar
HarleyViking
Ohhh ****, I've done it wrong all along Followed Hayes stupid manual (dont buy this one, also showed me wrong torque sequences in some cases) which says on the sidestand with the stick resting but not pushed down. Always showed on the low side but oil seeping from the rocker boxes! Now it stoped seeping and oil stick are almost on max with bike warm, level and dipstick pushed all the way down. Can overfilling cause leaking rocker boxes? Did I possible damage anything by running it that way?
Old Feb 23, 2020 | 12:37 PM
hattitude's Avatar
hattitude
In my experiences, the rocker gaskets leak or not... I suppose the oil level can affect them, but probably shouldn't....
I doubt you have any internal engine damage, breather seems to be working as designed... but I'm sure you're engine ingested more oil mist through the intake than normal, could have some extra carbon build up on the pistons... I always vent my engines to the air, instead of the intake... just don't think oil mist has any place in the intake... IMHO
As for the manuals, I learned long ago not use a Hayes, Chiltons, or any other non-factory service manuals for any of my vehicles. Especially for my Harleys, I use nothing but factory Service manuals.. I also buy a parts manual and Electronic Diagnostic Manual fo reach year Harley I've owned... they end up being great references, and I never sell them... I never know when I might want to get another shovel head, or EVO... I've amassed a decent library for just a private owner who maintains his own bikes...
Even the Harley Factory manuals will have a mistake or two, or need to be updated from changes in a procedure, like Service Bulletin M1416, dated November 4, 2015, 2008-2016 Harley-Davidson Touring Literature Update. Luckily, if you keep track of the Service Bulletins, you can adjust your old manuals to reflect changes
