Neutral safty switch?
Old Nov 18, 2021 | 07:32 AM
slickman's Avatar
slickman
Default Neutral safty switch?
Does a 07 softail have a neutral safety switch so it can't start in gear? I was told no, this true?
Old Nov 18, 2021 | 08:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
`07 is the first year for the neutral / clutch safety system.
You can start a bike while in gear, you just need to pull the clutch lever in.
Old Nov 18, 2021 | 09:10 AM
CrimSonami's Avatar
CrimSonami
but,,,,,,,,,,, if you have the tassels on the lever it might not be activating the switch. I put those on the wife's '16 Heritage and it was just enough t keep from contacting the switch so I had to remove them.
Old Nov 18, 2021 | 09:45 AM
mlbmd's Avatar
mlbmd
Had the same problem after adding tassels. Solved it by epoxying a small metal plate to the switch so that pulling the clutch lever in would depress the switch allowing starting in gear.
Old Nov 18, 2021 | 04:33 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Dan, I bet you didnt put those girly tassles on your levers.
Guys, I couldnt resist, try not to be to harsh on me...lulz
Old Nov 18, 2021 | 04:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Bike has no Tassles.
Bike has no name.
Bike is not a she or he.
Bike is just a machine, an `89 FLSTC.
Old Nov 18, 2021 | 05:10 PM
slickman's Avatar
slickman
i like Tassles, let the farts fly.
Old Nov 18, 2021 | 05:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I like your attitude.
Old Nov 18, 2021 | 06:19 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Tassels are just about the most ridiculous thing I have ever seen a person do to a motorcycle. There - that's that.
Old Nov 18, 2021 | 06:29 PM
slickman's Avatar
slickman
To each his own i guess. i like them.
