Hello im a fairly new rider and was wonder about a stage one upgrade when i bought my bike it had vance&hines slip on exhaust i was wondering if that would work or do i need a whole new exhaust pipes
Welcome to the forum, what model and year would help, but for a softail older then a 2017 the slip on mufflers would be part of a stage-1 upgrade, the catalytic converters are in the stock mufflers, hope this helps.
Ride safe.
Yes, if you truly have a 2020 Softail, then slip-on's are fine as the bike no longer has CAT...they're in the pipe(s).
This makes no sense.
It DOES have a CAT...in the pipes, not the mufflers. This means you need to either get new pipes, or bust the cats out of the stock ones unless you want the restrictive, performance robbing heat of cats.
