Inches are important
Old Feb 18, 2023 | 10:04 AM
Hilux1983's Avatar
Hilux1983
1st Gear
Default Inches are important
I have a 2022 SB. I'm wanting to install a taller set of bars without having to extend the lines. Any suggestions and pics of what y'all got?
Old Feb 18, 2023 | 10:39 AM
RGS88's Avatar
RGS88
About the maximum you can go without getting new lines or wire extensions is 6.5".
I have the 5.5" Drag Specialties pull back risers on mine, and I only had to re-route the clutch cable outside the fork stem area. One of my favorite changes I've made so far, made it much more comfortable on my shoulders and upper back, put the bars in a very comfortable position for me. I believe Durham has the same risers but added 1" spacers, which I would consider down the line just to try it.
Easy swap, took me about 40 minutes with a beer break during.
Old Feb 18, 2023 | 10:56 AM
Hilux1983's Avatar
Hilux1983
1st Gear
So, those are your stock bars with the 5.5 riser? Looks good. I'm hoping for the same result
Old Feb 18, 2023 | 04:41 PM
RGS88's Avatar
RGS88
Yep, stock bars. I may have turned them up just a hair as well, you have a bit of adjustability before you clamp them down tightly. Mine haven't moved at all in the 4k miles they've been installed.
08HD
Mar 3, 2017 08:56 PM
WhereduGo?
May 24, 2013 03:27 PM
jshull
Aug 19, 2009 02:46 PM
sledhead140
Dec 1, 2008 01:28 PM
Atomic Injector
May 4, 2007 10:33 AM
