Best spark plugs 96 Fatboy 80cubic in. 51,000 miles
Hello everybody how's everybody doing today, I got a 96 Fatboy I purchased about a month and a half ago seems like I'm having an issue with spark plugs can I get some advice on the best spark plug to use for a '96 Fatboy 51,000 MI running a little bit rich, I do have a 165 main jet to put in the carburetor I'm just wondering what's the best spark plugs to run I hear iridiums from some people to other people say no way help please anything would be of a help to me thank you. Here's a little more information that might help she starts out hold idle but driving down the road and a in town about 31 mph she gets a cough or a and backfires a little more than I think she should the more throttle I give her the smoother she goes, almost like a hiccup at low Cruise speed
Welcome! NGK 7634 BPR5ES-11 or if you want Iridium NGK 2115 BPR5EIX-11.
You'll find a lot of help in the Classic / Evo section since you have a 96 Evo. https://www.hdforums.com/forum/evo-84/
Thank you for the help just another question what's your opinion on the iridium plugs like I said I keep getting conflicting information. Are they hard on your motor
IMHO....
I will get the exotic, long-life iridium or platinum plugs for my Jeep, because you have to remove the intake manifold to change the plugs...
No need to spend that kind of money on a Harley. The plugs on a Harley are super easy to check, easy to replace, and cheap.... Just get a quality plug in the proper size and heat range.
Champion makes HD plugs and their Copper Plus plugs are virtually the same plug. They are like $5 bucks each.
In my old EVO I used the Champion 12YC5R6A currently about $5 each. (I currently use the Champion RA8HC 6R12 Copper Plus plug in my Twin Cams) I also used Autolite #4265 currently about $4 each. Some use the NGK BPR5ES-11 currently about $6 each.
I see no reason to spend $10+ each for the Platinum or Iridium plugs on a Harley. They give you no performance improvements and their long-life capability is unneeded.
Good luck with your decision...
IMHO....
You're welcome...
FWIW.... I currently own 4 Twin Cam Harleys. They all get ridden regularly here in SoCal, but because I have 4 of them, none really get "high mileage". Every two years, regardless of mileage, the plugs get checked. If they don't look brand new, they get changed out...
