Primary drain plug floating I知 around in primary case
Old Jun 25, 2025 | 06:46 PM
Fatboyguy89's Avatar
Fatboyguy89
3rd Gear
Default Primary drain plug floating I知 around in primary case
Well just as the title says, I did a stupid move and forgot to not screw the drain plug for the primary case all the way the way in. Well as soon as I started it up I immediately heard that terrible sound, and pulled the drain plug and the magnets gone. Needless to say that wonderful hunk of metal is floating around in the primary. My question is, is this a serious issue that requires me pulling the primary cover apart, or will it just get chewed up by the gears or chain and hopefully mixed in with the oil to be flushed out? And also is there any potential damage to clutch basket for any other internals that would be detrimental? It痴 a 1998 fatboy. Thanks in advance!
Old Jun 25, 2025 | 06:50 PM
MURPHCC1's Avatar
MURPHCC1
sounds like catastrophic damage if you start the bike!
The Compensator, primary chain adjuster, primary chain and clutch basket will be chewed up destroying everything in there.
Take it apart.
S.D.M.F's Avatar
S.D.M.F
If it was me..... I'd be pulling the primary cover off and finding it.
The magnet will make a mess of the clutch plates, especially the friction plates plus everything else.
Old Jun 25, 2025 | 07:21 PM
Rains2much's Avatar
Rains2much
Drain it
Remove the cover
Inspect everything
Remove primary chain (clutch, compensator, shoe)
Inspect the clutch and compensator teeth
Remove Stator
After thorough inspection order everything damaged new
Re-install
No short cuts.
Old Jun 25, 2025 | 07:37 PM
Fatboyguy89
3rd Gear
Take it apart.
unfortunately I did start it. And I took around the block for a test spin before the thought of the magnet possibly breaking off was a thought in my head, and ironically it was running really good lol. At first I thought it was just initial contact and that was it, but then after some research realizing that the magnet most likely broke off is when I started really getting nervous
Old Jun 25, 2025 | 08:22 PM
TriGeezer's Avatar
TriGeezer
Magnet is harder than any material in the primary. It will be the destructor not the destructee. Follow instructions from @Rains2much
Old Jun 25, 2025 | 08:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I`m missing something here, you forgot to screw the primary drain plug in, and somehow something is loose in the primary?
And....The primary drain plug is a tapered pipe plug, it does not get screwed all the way in...
Old Jun 25, 2025 | 09:02 PM
Uncle Larry's Avatar
Uncle Larry
He says he screwed it in too far
Old Jun 25, 2025 | 10:50 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Here is all I got to add. Pre-HD for me. A guy I worked with said the same thing happened to him. He said screw it, he left it and said the bike never shifted better than it did after that.
I don't know, just passing it on. It was a late 90s Dana.
Old Jun 25, 2025 | 11:19 PM
TwiZted Biker's Avatar
TwiZted Biker
Nothing good ever came of " f*ck it what can it hurt" with something maybe lose inside a primary. You like gambling big go for it.
