A/C suggestions???
Old 10-01-2007, 05:32 PM
allengator's Avatar
allengator
allengator is offline
Default A/C suggestions???
I am thinking of adding V&H true duals with fishtails, and a V&H FuelPak.........
Any suggestions on a good air cleaner that will work well and tune easily?
I am not planning on other power modifications.... is the stock one good enough?
Old 10-01-2007, 06:21 PM
CraigW's Avatar
CraigW
CraigW is offline
Stage IV
Default RE: A/C suggestions???
I have a Kuryakyn Hypercharger that appears to work well although it was pricey and tends to push into your knee a bit...I have seen others post that Hypers are a bit of overkill....but hey, it looks fantastic!
Old 10-02-2007, 03:33 AM
skulznflames's Avatar
skulznflames
skulznflames is offline
any aftermarket will be better than stock - Screaming Eagle, Arlen Ness, all cheaper than Kuryaken and just as equally effective.
Old 10-02-2007, 08:45 AM
gunner065's Avatar
gunner065
gunner065 is offline
I'd have to vote for a K&N. My SE AC, black one, started to disengrate on the inside after 600 miles. Brought it back to the dealer and they gave me a K&N that they had left over from the days when they were installed as part of Stage 1. Can't tune it though.
Old 10-02-2007, 09:06 AM
PoorBoy's Avatar
PoorBoy
PoorBoy is offline
Everything I've been told says you need to open BOTH ends for the engine to breath right and tune correctly. Any high-flow a/c will accomplish that when added to new pipes. You don't want to keep your stock a/c.
I went with the Arlen Ness Big Sucker that mounted easily behind existing football cover. K&N hasmodels that mount that waytoo. If you're not attached to your football cover, there are numerous options that satisfy V&H's request for a high-flow a/c to go along with any of their pipes andtheir FuelPak.
You will be VERY happy with the results of Stage 1 mods. If you already have synthetic oils in your holes, you'll also be very happy how cool your engine will run after Stage 1 is done!
Cheers!
Rwillden
2014-2023 Touring Models
05-01-2015 11:00 PM
BLMC
12-11-2009 10:54 AM
Dethlace
05-09-2008 03:19 PM
DeeRoe
12-23-2007 10:39 AM
JDean
Exhaust System Topics
05-17-2005 07:06 AM
Quick Reply: A/C suggestions???
