Oil again
Old Nov 10, 2007 | 10:40 AM
eagle56's Avatar
eagle56
Default Oil again
asked my dealer if fuuly synthetic on the 1000mile change will be better.
they said it it a slow reving motor and the standard HD oil is recomended.
It the HD oil semi?? or just Dino oil.
I will be strongly concidering fully
what do you guys think.
Old Nov 10, 2007 | 10:52 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Oil again
Another dumb dealer heard from, go synthetic. And from now on double checkanything you hear from that guy.
Any of the name brand synthetics will bea better choice for your bike, even HD's own Syn3 is better than the dino stuff.
Amsoil, Mobile 1, Redline are all at least as good and for the most partbetter, and cheaperthan even Syn3.
Just make sure you use the bottle's marked "forV-Twins" and you'll be fine.
Old Nov 10, 2007 | 11:27 AM
voyager1's Avatar
voyager1
Many peoplesay wait till 5000 miles before synthetic ??
xxxflhrci's Avatar
xxxflhrci
Run any oil that is approved. Check your owner's manual for info. I've yet to see a worn out engine from running an approved oil and changing it when needed. Sure, top end jobs on bikes from 2 decades was the norm every now and then, but them days are basically over.
Me? I run 1.99 a quart dino in my Twin Cam and Pennzoil dino in my Ironhead. The Twin Cam has 68k miles on it, runs like new, doesn't need oil added between changes, and doesn't smoke.
Old Nov 10, 2007 | 11:58 AM
Waltman's Avatar
Waltman
My stealer recommended Syn3 at the 1,000 mile service. 11,000 miles later my Fat Boy is running with no problems at all. Just keep in mind Syn3 goes at almost $10 per quart!!
Old Nov 10, 2007 | 02:23 PM
PoorBoy's Avatar
PoorBoy
Yup, I agree with Citoriplus. Two or more pieces of metal rubbing together at any cadance will benefit from synthetic oil. The big deal about synthetic oil is that it is harder to breakdown by offering higher heat tolerances and smaller molecules (than dino).
As many say, you can certainly survive on most of the dino oils, but why not treat your ride to the really good stuff?
Another benefit to the synthetic oils is that you can expand your time between changes. (most advertise as 5-10 thousand miles between changes). I ignor this by using Amsoil every 5,000 miles. Next time I am switching to Mobil 1 V-Twin because I see it everywhere.
Old Nov 10, 2007 | 08:15 PM
pococj's Avatar
pococj
Don't need to worry about whether it says "V-twin" on the can. Any synthetic of the right weight will work fine. Mobil 1 15w-50 is one that comes to mind. And an excellent non-synthetic oil is Havoline 20w-50.
Old Nov 11, 2007 | 05:57 AM
whitebread_30's Avatar
whitebread_30
If you change your oil often it dont matter what kind you use. I go with Synthetic though cause I want the best for my baby. More than likley I am wasting money but wtf.......
Old Nov 11, 2007 | 06:19 AM
Heritage07's Avatar
Heritage07
Good artical in this months American Iron on why Harley took so long to recomend and come out with thier own synthetic oil. Bottom line they say was years of testing and developing thier own Syn3.
Harley does not recomend any other synthetic simply because they have not tested them in their engines and of course they won't because they have their own brand! Any dealer that tells you not to use Syn3 is living in the stone age.
Old Nov 11, 2007 | 08:47 AM
rockerhead's Avatar
rockerhead
syn3 is made by CITGO A Communist Dictator owned oil
company. Please do not support!
