The fat boy is nearly finished
Old 05-01-2008, 08:57 AM
MICHALISLARNACA's Avatar
MICHALISLARNACA
MICHALISLARNACA is offline
Default The fat boy is nearly finished
Took me the better part of three months to complete the bike and I am last on waiting for the relocation of the blinkers from biker gear.
I will post pictures of the final product when its completed. these are but a few.
103 ci kit
oil cooler
lower suspension back
front suspension inner workings changed with new valves
rotors changed
lyndall brake pads
hidden all wires
front passing lamps and relocation of turn signals
chrome covered the engine
marlin temp reader and pressure reader
changed all the cables to SS
changed clutch springs and had bigger ***** from engine ball bearings stripped down (they are a 0.65mm bigger - a lot of dif.)
arlen ness stage II air intake
speedway tacho
efi fuel pak
kuryakyn wild things intake and injectors
true duals V&H
Old 05-01-2008, 01:59 PM
Tin Gizel's Avatar
Tin Gizel
Tin Gizel is offline
Default RE: The fat boy is nearly finished
If you think you're going to be done when all the above is installed then you need help. You're never done. Rule #1 with Harley's, you are NEVER done....
Old 05-01-2008, 03:08 PM
SoftailNix's Avatar
SoftailNix
SoftailNix is offline
You are always "close" though....lol Or else you are "done for this winter"
caltak
03-23-2018 11:19 AM
shari
05-19-2013 09:35 AM
kuahiwi
10-04-2012 06:50 PM
Black Beauty
10-26-2011 09:01 AM
KYFATBOB
03-15-2010 01:02 AM
Quick Reply: The fat boy is nearly finished
