New seat install question
Old 05-01-2008, 01:35 PM
jm35ny's Avatar
jm35ny
jm35ny is offline
Default New seat install question
Hi guys i just got the Lepara Bare bones for my 07 softail custom, before that it had the original big king queen seat. The seat fits perfect but i need the new seat didn`t come with the hardware to bolt it to the bike. It looks like there is a plastic plug in the fender that needs to be removed and then i need to get a nut and bolt to secure it to the rear fender. Has anyone had any experience with this?
Old 05-01-2008, 02:01 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
Default RE: New seat install question
There is a special nut that fits under the fender and a thumbor slotted screw to hold it on with. The dealer should be able to get it for you, might even have one in stock.
Old 05-01-2008, 03:42 PM
jm35ny's Avatar
jm35ny
jm35ny is offline
ok that makes sense now, thanks.
Old 05-01-2008, 08:41 PM
bubiker's Avatar
bubiker
bubiker is offline
Hey jm35ny,
The part you're looking for is part no. 59768-97 in the harley parts book and costs $2.50; it's called a "fender seat nut kit". This nut will work with the stock bolt that held the passenger seat.
Real easy install too. Just put some double-sided scotch tape or similar at the end of a long screwdriver or stick, look through the hole in the fender and start feeding the fitting stuck to the end of the stick upward inside the fender until you see the tip protruding through the hole in the fender. Slip on the plastic retainer ring while still holding in place with the stick and voila you're done. Takes less then 1 minute to install ...
Hope this helps.
[IMG]local://upfiles/51518/B26E7C8B343C44FEBB70F4F0FD84DF4B.jpg[/IMG]
Old 01-24-2013, 09:04 AM
rs87277's Avatar
rs87277
rs87277 is offline
i need to order two of these, hope the dealer stocks them cause shipping is like 9.99 on the web sites
Matt990724
EVO
10-14-2017 12:19 PM
blueangel73
08-07-2014 09:09 PM
WhiskeySierra
12-01-2011 03:25 PM
bikerlaw
02-07-2011 07:01 AM
jb1023
04-05-2010 06:39 PM
Quick Reply: New seat install question
