larger rear wheel for an 04 standard
05-01-2008, 02:35 PM
can you put a larger dia. on this bike? any photos out there?
05-02-2008, 12:43 AM
RE: larger rear wheel for an 04 standard
I have a Metzler chart I can email you that has the stages for increasing size and what needs to be done and what will fit.
05-02-2008, 07:58 AM
if you could that would be great.
05-02-2008, 08:44 AM
Quote:
ORIGINAL: mhughes600
18" wheel will fit with no issues
05-02-2008, 12:52 PM
the swingarm is the same as a 06 standard with 200 tire. u can put on a 18 x 5.5 with a 200 tire if you get the right spacers and offset spacer for the tranny.
05-02-2008, 01:10 PM
But will that 200 fit in his fender. The bobtail fenders on the 06 FXST's and the 07 customs thathave 200 rearsare much wider than the 04 FXST fender.
05-02-2008, 01:18 PM
You can run an 18" rear wheel, but you will have to stay with the same size tire unless you modify (widen) the rear fender and struts.
05-02-2008, 01:47 PM
thanks for the info, i wanted to go to an 18 if possible. so then i should only lower the profile of my tire.
Mikeachriste
09-24-2013 02:31 PM
SoZoomMe
Wheels/Tires
07-04-2012 07:20 AM
drd21968
10-23-2008 08:51 PM
Miklnparker
General Topics/Tech Tips
03-11-2008 07:33 PM
Tbolt04
06-17-2007 02:01 AM
