Handlebar change.......with pics
Old Nov 5, 2008 | 09:55 PM
mimo's Avatar
mimo
What total lenght of Clutch, thr/id, and brake line did you use brother?
I got a 77" for the Clutch
54" for the brake line
and 46" for thr/idl
I wonder if that will suffice, I hope I measured well...
Old Nov 5, 2008 | 10:08 PM
Rabbit_'s Avatar
Rabbit_
Nice thread Mojo, I wanted to do the same when I installed my Apes but kept forgetting to take pictures. What Apes did you get?
Old Nov 5, 2008 | 10:21 PM
mojojones's Avatar
mojojones
and 46" for thr/idl
I got Sterling Chromite cables and brake lines; nice stuff, looks identical to HD diamondback, except the clutch cable is braided all the way to the trans side plate, and the adjusters are nicer. Local indy sold it to me cheaper than I could have gotten it online anywhere.
Clutch was 78", 58" brake line, 46" for thr/idl.
Everything was perfect.....the only thing you have that may be short is the brake line. At 58" I didn''t have much xtra, but I'm using the inverted forks that are about 2" longer than stock, and my front end is not lowered, so you may be OK.
I used the Namz harness extension kit; it was much cheaper than the Novello and worked very well.
Old Nov 5, 2008 | 10:24 PM
mojojones's Avatar
mojojones
Carlini gangsters 1.50's in an 18" rise. I also got the Carlini 1 piece billet riser........really nice stuff.
Old Nov 6, 2008 | 10:41 AM
mimo's Avatar
mimo
So I see, thank you. But I see you do have risers still, right??? Mine is a Fat Boy so I don't know if the fork overall lenght is minor vs your bike's.
Great post, thank you for the info.
Mimo.
Old Nov 8, 2008 | 04:43 PM
ronyd's Avatar
ronyd
Just as a tidbit, don;t have to remove pipes. Just loosen them up at the jugs, and mufflers brackets. Use a round headed allen wrench for the tougher bolts to get at. there's enough clearance. Just what I did...
Great job man!!
Old Nov 8, 2008 | 08:02 PM
url8's Avatar
url8
Mojo don't like the look.......I ABSOLUTELY LOVE THE LOOK!!!!
Old Nov 8, 2008 | 09:29 PM
WARG's Avatar
WARG
Very cool man.
Old Nov 22, 2008 | 01:20 PM
m i k e's Avatar
m i k e
you've inspired me to do this transformation on my rock
pics soon,ordering parts so i gat everything was at dealer today got
sevice manual,o rings, trans gasket,anti sieze stick,washers
besides cables did i miss anything?thanks
Old Nov 22, 2008 | 02:23 PM
tripwire759's Avatar
tripwire759
Nice job mojo.
