ISO Throttlel Grip Sticking
Old 12-14-2008, 06:12 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Default ISO Throttlel Grip Sticking
Installed new bars with ISO grips and the throttle grip does not return when you give it some throttle and let it go. If I pull it out about 1 to 1 1/2 inches it turns much freer. I reinstalled my old throttle grip and it works fine - plenty of return snap. I put wd40 on the bar and that seemed to help quite a bit although not like the old throttle grip... I also put the ISO grip on the old bar and it seemed to have the same resistance as on the new bar. Any suggestions?
Old 12-14-2008, 07:20 PM
rbabos's Avatar
rbabos
rbabos is offline
Sand the bore of the grip out until it turns freely.
Ron
Old 12-14-2008, 08:14 PM
wildman67's Avatar
wildman67
wildman67 is offline
Are you sure your throttle and idle cable's are adjusted correctly?
Old 12-14-2008, 08:42 PM
5speedblu's Avatar
5speedblu
5speedblu is offline
is it tight on th bar? install it with no cables? is it tight? try to return it b/4 you sand it or you will be stuck with it.
If the new one is the same then sand it like rbabos said.
Old 12-14-2008, 09:27 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Yes, tight on the bar by itself, not installed. Like I said, I reinstalled the original and it worked fine. The original also turned freely by itself. Definitely an issue with the new grip
Bilco60
06-01-2013 10:15 PM
tacoma5432
05-25-2011 07:40 PM
OneBlackFly
08-22-2009 10:40 AM
rpmarkley
04-22-2009 11:05 PM
fatbob422
05-01-2008 10:21 AM
Quick Reply: ISO Throttlel Grip Sticking
