A Gripping problem
Old Jun 1, 2013 | 01:01 PM
Bilco60's Avatar
Bilco60
Angry A Gripping problem
Ok, bought new grips, hd get a grip or the bike. Read all the instructions, watch the video. Seems very straight forward. Remove old throttle grip, so far easy. Put new grip on still easy. Tighten everything up throttle will not return to position. Take it apart apply som grease to throttle cables look it over reassemble, adjust throttle still sticks. Take it back apart apart look it over. Can't see any issues. Put it back together and adjust everything sticks. Now I'm getting pi$$ed. Take it apart put old throttle on adjust every thing, works fine. WTH? Any ideas what is wrong? New throttle looks fine.
Old Jun 1, 2013 | 01:11 PM
Dynam1te's Avatar
Dynam1te
Give the throttle lock a twist underneath. My guess is the grip are a different size so the throttle lock is catching on the new grips. Try that out because, there really isn't a whole lot else going on in that area...
Old Jun 1, 2013 | 01:50 PM
_Gir_'s Avatar
_Gir_
When you tighten the box with all the switches on it down on the bars, don't have it as far as you can to the left.
Leave a little slack for the handle to spin freely away from the end of the bar.
Old Jun 1, 2013 | 02:00 PM
maddghost's Avatar
maddghost
Good Ideas my first guess was the same as dynamite. The new grip may be slightly thicker for your old lock setting.
_GIR_ there's not really a choice as the throttle cables need to be inside the housing.
Old Jun 1, 2013 | 03:47 PM
HD Pilot's Avatar
HD Pilot
I think Gir is suggesting moving the throttle housing to the right a bit in case the Get-a-Grips are slightly shorter than stock - catching on the end of the bars.
Old Jun 1, 2013 | 03:50 PM
Junkster's Avatar
Junkster
Thats really the only two things it can be. Usually its the throttle lock.
Old Jun 1, 2013 | 04:35 PM
_Gir_'s Avatar
_Gir_
Correctamundo!
Old Jun 1, 2013 | 05:39 PM
Bilco60's Avatar
Bilco60
Thanks for all the help. I thought I had the throttle lock all the way out, but will check it when I try again. It did seem slightly shorter. Did not bind until I tighten the housing.
Old Jun 1, 2013 | 10:15 PM
Bilco60's Avatar
Bilco60
Ok, went out this evening and tried again. Success, needed to move the brake assembly 1/8 inch right. No longer binding.
DigbyHD
May 30, 2014 05:47 PM
mikeo33y
Jan 1, 2014 11:01 AM
OceanState401
Jul 22, 2009 12:46 AM
AdrianVall
Dec 26, 2008 11:45 AM
KumaRide
Dec 14, 2008 09:27 PM
