primary -trans oil change ???
Old Dec 18, 2008 | 11:40 AM
ozzy07840's Avatar
ozzy07840
Default primary -trans oil change ???
Hi i have a 07fxst that i put away in the shed for the winter in nov , just before that i had 20,000 mile on the odometer and changed the primary trans and motor oil ,in the spring when i get it out of the shed do you think i should change all 3 holes again ??? thanks for your time Rich
Old Dec 18, 2008 | 12:05 PM
sonar_chris's Avatar
sonar_chris
IMO you dont have to, but in reality, if it makes you feel better to change it out, then go ahead, a few dollars to give yourself a piece of mind might not be bad.
Old Dec 18, 2008 | 04:25 PM
hpfatboy's Avatar
hpfatboy
Talking
As long as your shed is warm and dry, i think you will be fine for next year. MOISTURE IS A KILLER, and the result from being in a wet and damp enviroment. I also change out my fluids before storage because of the ACIDITY that occurs from the natural breakdown of the oil itself during use. IF THE SHED IS WARM AND DRY , i believe you are ready to go come spring time. IF IN A WET DAMP ENVIROMENT, sure change oil out before you ride in spring. GOOD LUCK
Old Dec 18, 2008 | 04:41 PM
barjbar's Avatar
barjbar
You're supposed to change the fluids before storing the bike. You're bike will be fine 'till spring. Cover it with a quality bike cover, Stabil in the gas tank, and trickle charge hooked up to the battery and you're all set.
Old Dec 18, 2008 | 06:43 PM
Blk and Chrome's Avatar
Blk and Chrome
All the above good things to do, mine is in my buddies basement, warm and dry just waiting for winter to be over
Old Dec 20, 2008 | 11:17 AM
hdbe's Avatar
hdbe
I always change before i put it away...
Old Dec 20, 2008 | 11:08 PM
anubisss's Avatar
anubisss
What's this "put away" you speak of?
Old Dec 21, 2008 | 05:56 AM
bL33d's Avatar
bL33d
I just bought a new battery not a month ago and dont want it to go bad should i hook up a trikle charger to it? If so what is the process just leave it on all the time? at lowest setting?
Old Dec 21, 2008 | 06:23 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
bL33d Yes , plug it in immediatley. Especially now with the cold weather. I have the harley trickle charger, and use it all year round. Soon as i get back from a ride , just plug it in. Mine has no settings, you just plug in and it charges according to the voltage. Once reaches 12 volts cycles off, goes below certain pre -set voltage cycles on. It acts exatly like a thermostat, which is what it is. You will do no harm to battery as long as it stays at peak voltage. Its when you drop below voltage , that the damage can occur.
Old Dec 22, 2008 | 06:19 AM
bL33d's Avatar
bL33d
Thanks im gonna hook it up today as its bitter cold out.
Buckinfitch
Dec 4, 2016 01:43 PM
hemi1300
Dec 8, 2015 08:43 AM
traildog
EVO
48
Feb 18, 2014 07:22 PM
J-Train
Mar 12, 2010 03:59 PM
richmac64
May 2, 2007 03:22 AM
