Changing Oil Question
Old Apr 8, 2009 | 02:49 PM
flyboyron's Avatar
flyboyron
Default Changing Oil Question
Well it is getting to 5,000 miles and I thought I would do the service myself.
When I change the oil, I need to remove the oil filter.
Now when I had my Ultra Classic, I bought a curved plastic drain pan that fit under the oil filter and then had a drain hole at the other end so it would drain into a pan and prevent the oil from getting on the engine and frame.
Would I use this same type on the 08 Softail Custom?
It seems like the forward controls would be in the way. I don't know if they fit all bikes or not. If I have to buy one, I want the correct one. I tried cardboard for a while when I had my Ultra Classic and gave up and just bought the plastic filter drain piece.
What do you guys use when you remove the oil filter?
Thanks in advance.
Ron
Old Apr 8, 2009 | 03:25 PM
Mike NY's Avatar
Mike NY
I use a plastic 1QT Milk Container. Cut a section out along the top and front (bottom of container) and slip it under the Oil filter and unscrew the filter and let it drop in. I usualy loosen the filter a bit first so I can use my hand to loosen it the rest of the way.
Have some rags ready just in case.
Mike
NY
Old Apr 8, 2009 | 03:53 PM
PureDeath's Avatar
PureDeath
I use a empty toilet roll holder , ( cut the paper down the middle ) side it in between the filter and let it go.
Old Apr 8, 2009 | 04:07 PM
pearlandhd's Avatar
pearlandhd
I use a 1 liter coke bottle. Do a seach on google and you'll get the idea.
x1 on have some rags ready just in case.
Old Apr 8, 2009 | 07:46 PM
powaypete's Avatar
powaypete
Thanks in advance.
Ron
Oil filter is the same
I use a strap wrench to loosen the filter, just be careful of the sending unit below the filter.
Old Apr 8, 2009 | 08:57 PM
anubisss's Avatar
anubisss
Tin foil...
Old Apr 9, 2009 | 06:12 AM
NotSoStandard's Avatar
NotSoStandard
I've given up on all methods of catching the oil without making a mess. Every method I have tried ends up spilling some oil. Now I just let it make a mess and clean up after. It is quicker and I always had to clean up anyway.
Old Apr 9, 2009 | 09:04 AM
ronyd's Avatar
ronyd
I tried the tin foil and the zip lock bag and still made a mess. Pissed me off. Next I'll try the bottle trick. Maybe by my next oil change I'll have an emtpy toilet roll hanger (can;t make this one up eah!!)...
Old Apr 9, 2009 | 10:10 AM
softail04's Avatar
softail04
tried all the methods and still make a mess so now I just take it off then get a can of some kind of carb cleaner and clean up the mess easy and it needed cleaning anyway
Old Apr 9, 2009 | 12:00 PM
Called2Duty's Avatar
Called2Duty
lmao!
