Throttle cable Routing
Old Aug 25, 2009 | 11:12 PM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
Default Throttle cable Routing
I recently changed out my throttle/idle cables with the Barnett Stealth Series and they seem to be too long. They're the same length as the stock cables. Im not sure if they run in front and through the forks or do they run completely behind Sorry for the blurry cell phone pic.
triple tree like the brake line ? Here is a pic of how they are currently running ..
Old Aug 25, 2009 | 11:30 PM
story808's Avatar
story808
SE can you slide them in more? Without causing a extreme bend? Have them pass the carb then come back to the carb. Cables running in front the trips are not going to look good IMO.
After looking at the pic are you running the cables through the clips that your wires are running through that may help?
Old Aug 26, 2009 | 12:01 AM
ScReaMnEagLE22
They are routed the same way the stock ones were. That little p clip is only for the brake line. Nothing else will fit. Yea I agree as for running them in front. I recently changed to 4" risers, making the problem worse, they looked long with the stock 6", Now they look even longer.
Athough I have read several threads that guys have kept their stock cables when going to the 4" risers.
Old Aug 26, 2009 | 12:27 AM
stupid_rope's Avatar
stupid_rope
Run it in front of the steering head
Old Aug 26, 2009 | 02:47 AM
IronAss's Avatar
IronAss
Should route the same as stock one's. It's very important that they be routed correctly. BTW I looked at the vid of your SE Fatboy and was just wondering....Was the button where to right turn signal usually is a primer or something? Sorry, couldn't resist.
Old Aug 26, 2009 | 02:10 PM
story808's Avatar
story808
Sorry I was talking about the wires coming from the trips if you run it through there it will move it up and in some and not be hanging out there? Just a thought, M
georgy51
Jun 22, 2013 02:33 AM
Figstr
May 6, 2012 07:51 AM
warrick
Jun 15, 2011 08:05 PM
mattgenk
Aug 7, 2009 09:09 PM
Steel
Jan 15, 2008 09:32 AM
