Throttle cable questions
Old Aug 7, 2009 | 01:41 PM
mattgenk's Avatar
mattgenk
6th Gear
Default Throttle cable questions
I'm swapping stock buckhorn bars for 10" mini-apes on 4" risers (Thanks to Rick1972, I figured out how to mount the speedometer to the risers). The stock cables aren't cutting it, so I'm ordering up stainless steel cables. Only problem I'm running into is finding throttle/idle cables that will fit the new bars & risers. I've made my measurements and need at least 42 inches of housing length in order to run the cables up the new handlebars. I'm pretty sure that all of MoCo's OEM cables (for Dyna and maybe softail, all have a 90 degree bend) have the same travel length measurements, but I'm not 100% sure and I haven't spoken to a parts rep at any of the dealerships that could answer this question. I'll state my question... now...
Are the travel lengths on all Harley Davidson OEM throttle/idle cables the same?
If so, I should be able to pick the housing length I need and forget about the travel length?
Thanks for your help.
Old Aug 7, 2009 | 03:19 PM
mud's Avatar
mud
matt, I would guess - yes.
Are we talking FI or carb??
what year??
mud
Old Aug 7, 2009 | 03:46 PM
CountryPunk's Avatar
CountryPunk
Another idea is losing the idle cable altogether. Just put a spring on the throttle arm of the carb, if you still want the dual cable effect without the cable. It'll clean things up a little bit.
Old Aug 7, 2009 | 07:06 PM
mattgenk's Avatar
mattgenk
6th Gear
Mud - Yeah, it would have helped if I had mentioned that I'm working with a carberated model.
Punk - I've never heard of putting a spring on the throttle arm of the carb, but I'll search the forums to see if there any posts here.
Old Aug 7, 2009 | 09:09 PM
CountryPunk
I only know of one person on the forum that has done this. It's a lot more common in the "chopper" circles. The spring isn't necessary, but Does make things safer.
ed gien
Aug 17, 2020 12:48 PM
RidemyEVO
EVO
Aug 19, 2012 03:11 PM
piercings4_u
General Topics/Tech Tips
Apr 8, 2011 03:47 PM
mphillips
Sep 7, 2009 02:10 PM
rgm
Apr 21, 2008 02:11 PM
