pushrod tight and wont start
Old Sep 22, 2009 | 07:28 PM
softailman007's Avatar
softailman007
5th Gear
Default pushrod tight and wont start
OK well I just replaced my cam rollers and i put every thing back on i adjusted the pushrods exept for the rear cylinder one that is close to the engine it is adjusted to as small as it will go and it is still tight. also i cracked the middle rocker cover. But my engine will not start it will start for maybe a half secound and just keep trying but will never turn over and its like you can year a loud metal noise like the piston traveling or something up and down a loud knocking sound. PLEASE I am desperate for any help.
Old Sep 22, 2009 | 08:42 PM
softailman007
5th Gear
bumpin up for a reply..... maybe i have the pushrods in wrong location?????
Old Sep 22, 2009 | 08:51 PM
DyNaBoB's Avatar
DyNaBoB
sounds like you over your head .........................take it into a mech
Old Sep 22, 2009 | 09:02 PM
mike06train's Avatar
mike06train
+1 This could get expensive real fast.
Old Sep 22, 2009 | 09:21 PM
oct1949's Avatar
oct1949
the metal sound don't sound good, if its out of time then U can damage the valves, not sure what u done, but need to check to see what has happened...
Old Sep 23, 2009 | 12:08 AM
av8or's Avatar
av8or
Sounds like cam timing is off. also sounds expensive at this point, if you hear knocking damage is already done.
Old Sep 23, 2009 | 03:09 PM
Northside's Avatar
Northside
What is a cam roller? Did you change the rollers on the lifters? Cam bearings? All of the pushrods are "close to the engine!" If your pushrod is adjusted to as short as it will go that banging might be that looser than hell pushrod rattling around. The lifters need to be at the bottom of their travel and you need to wait 20 to 30 minutes after rotating the engine before you adjust the pushrod. That's so the lifter will bleed down. You do have adjustable pushrods? Follow the instructions for the brand of pushrods you have, some have a 3/8-24 thread which move a shorter distance per turn than other brands which have 3/8 -16 threads. And yes the pushrods are different lengths. If none of this makes sense to you haul it to a wrench who does understand.
Old Sep 23, 2009 | 06:01 PM
boosteddelslow's Avatar
boosteddelslow
Most of the time when you hear metalic banging sounds from an engine it is time to start looking for a problem instead of trying to get it to start.
Old Sep 23, 2009 | 07:14 PM
softailman007
5th Gear
O really boy that is a genious reply!
Old Sep 23, 2009 | 07:16 PM
softailman007
5th Gear
I replaced the hole tappets and cam and cam bearing. and yes I was refering to the one that was closer to the engine I forgot which is which however i fixed the pushrod problem.. however when i go and try and start you hear a loud cla clunk pretty much stuck on haveing a clue what it is.
