Springer front end help
Old Nov 8, 2009 | 12:33 PM
scorchedearthpolicy's Avatar
scorchedearthpolicy
Default Springer front end help
Has anybody ever removed the shock off the front end and rode like that? Just curious how the ride is mostly. I thought maybe it would give it a little old school flavor.
Old Nov 8, 2009 | 12:35 PM
2003Springer's Avatar
2003Springer
Never done that but it is old school with the shock off. I have a 2003 FLSTSI Heritage Springer. I would be afraid to try it. But let us know if you can still type when you try it.
Old Nov 8, 2009 | 01:36 PM
scorchedearthpolicy
I'm thinking about removing it and moving my headlight to the lower shock mount.
Old Nov 8, 2009 | 02:37 PM
bensonjv's Avatar
bensonjv
You can do it but...
Not sure but highly likely that Spring strengths have been adjusted from 1948 specs in order to optimize performance and cooperative effort with shock.
Attached Thumbnails Springer front end help-2337249170100842438s600x600q85.jpg
Old Nov 8, 2009 | 09:13 PM
xraybox's Avatar
xraybox
Whats going to happen is after you hit a bump your front end will have a tendency to keep bouncing, it shouldn't be unmanageable.
The springs "strength" isn't affected by the shock.
The springs carries the load, the shock dampens the springs tendency to keep bouncing.
Old Nov 9, 2009 | 06:55 AM
pbasz's Avatar
pbasz
Taking the shock off is kinda like washing your bike without using the specified factory cleaning spong and soap.....it will void your warrranty and "could result in injury or death".
The older springers had a friction damper on them to help reduce the bouncing. You could get a bracket made to allow you to mount the headlight lower and keep the shock.
Old Dec 1, 2009 | 12:13 PM
Smokey Burnouts's Avatar
Smokey Burnouts
Most of your aftermarket Springers dont have them!! Like stated already, think it might make it "bouncy"... DO IT!!
Old Dec 1, 2009 | 12:56 PM
wyndnface's Avatar
wyndnface
I got a feelin that it's there for a very good reason
Old Dec 1, 2009 | 01:02 PM
tmd442's Avatar
tmd442
I'm curious also, Let us know.
I just put a Progressive shock on my springer. The Front end seems a bit more stable over rough roads.
Old Dec 1, 2009 | 01:24 PM
Ole Coyote's Avatar
Ole Coyote
It's bounce. Don't ask me how I know, but I had to much time on my hands this summer, with all that friggin rain and chit. Shocks back on and staying on.
