Help with Heritage softail
Can someone tell me what the frame to ground clearance should be on a flstsi Heritage softail that has not been lowered Mine sets 4.0 inches in front of the back wheel (Frame) and 5 inches rear of the front tire. I am speaking of frame to ground. Is that about correct?
GENERAL INFORMATION 2003 FLSTSI
Manufacturer Harley-Davidson®
Model Year 2003
Model FLSTS/FLSTSI Heritage Springer®
Color Gunmetal Pearl
Stock Number: B5789
Miles 29010
ENGINE
Engine Twin Cam 88B™ (balanced)
Displacement 1450cc (88.0 cubic inches)
Bore x Stroke 3.75 x 4.00 in.
Torque 85.0 ft. lbs. @ 3000 rpm
Compression Ratio 8.9:1
Fuel System 40mm Constant Velocity Carburetor with Enrichner and Accelerator Pump or Electronic Sequential Port Fuel Injection (ESPFI)
Clutch Multi-plate clutch with diaphragm spring in oil bath
Exhaust Crossover dual fishtails
DIMENSIONS
Length 94.1 in.
Weight 716.6 lbs.
Ground Clearance 4.9 in.
Wheelbase 64.2 in.
Fuel Capacity 5 gal. (Includes reserve on carburetor equipped models)
Seat Height 25.9 in.
DRIVETRAIN
Transmission 5-speed
Final Drive Carbon Fiber Belt
Suspension Springer Front Suspension
OTHER
Options ESPFI (Additional $600.00)
H-D® Factory Security System (Additional $275.00)
BRAKES/WHEELS/TIRES
Brakes Front: 11.5 in. x .20 in.
Rear: 11.5 in x .23 in.
Tires Front: MT90B16 72H
Rear: MU85B16 77H
Model Year 2003
Stock Number: B5789
Miles 29010
ENGINE
DIMENSIONS
Length 94.1 in.
Weight 716.6 lbs.
Wheelbase 64.2 in.
DRIVETRAIN
OTHER
BRAKES/WHEELS/TIRES
Rear: MU85B16 77H
With the bike you have you need to check this place out:http://www.heritagespringer.com/history.htm
Hey...That place looks pretty cool....
sprocketlist
Motorcycles For Sale
Mar 28, 2014 08:45 AM
sigmund
Feb 28, 2012 08:41 PM
