Bike won't start sometimes but battery is strong
Old Dec 18, 2009 | 08:26 PM
cbrenthus's Avatar
cbrenthus
Originally Posted by FLSTC4ME
Sounds like battery to me too! Just cause it's new doesn't mean it's good!
+1. I have replaced bad parts with brand new bad parts many times. The first thing you need to do is take the battery to an auto parts dealer and have it tested. Make sure it is good. If the battery tests out good, then look into the charging and starting systems.
Old Dec 18, 2009 | 09:59 PM
2kids3pets's Avatar
2kids3pets
Originally Posted by edge1
Hi all! I was hoping someone could give my some advice here. I have a 2003 fatboy. I've been taking really good care of it over the years. Recently when I try to start it, it won't turn over and all I hear is this ticking/clicking noise on the left side. Now, I know the battery is strong. I just bought a new one over the summer and I always have it connected to a battery tender when I'm not using it. I was wondering, do you think that maybe my plugs are just bad and I'm not getting good spark? Thanks to who ever can point me in the right direction.
Sounds like a battery to me, a battery can fail for various reason Will it start if you jump it...it it does its the battery for sure
Old Dec 19, 2009 | 02:47 AM
story808's Avatar
story808
When you say clicking or ticking... Is it a loud clack, clack, clack? your is it a faint ting?
The clack would be battery and the ting would be the starter relay... BTW you say sometimes? what exactly does sometimes mean? Like you'll be riding stop somewhere and press the start button and nothing? Then keep pressing it then and all of a sudden it starts?
if it's something like that check the battery cables if that doesn't work change the starter relay it's like 7 bucks at the dealer and it's under the seat so it's cheap and easy. Do you have a alarm system?
Old Dec 19, 2009 | 04:05 PM
soft 02's Avatar
soft 02
It could be your over run clutch in the starter. Its the weak link in harley starters. I know because ive replaced two in my bike and im not the only one. This time it sounded like it was throwing the gear out but not spining the motor over at all. Took it apart today and found my over run clutch ( sprag clutch) was bad.
Old Dec 19, 2009 | 07:24 PM
Lucky 13's Avatar
Lucky 13
you might want to check the ground connections. I think the starter bolts make the ground for the starter but the battery does ground to the frame and that connection sometimes gets corroded
Old Jun 11, 2022 | 10:10 AM
Jarhead71's Avatar
Jarhead71
Stage I
Default No start
I have a 03 ultra.
Here is the deal. I don't ride a lot and when it sits in the garage it is not on a tender, unless it is winter time.
From time to time when I go out and try to start it , it will not fire. every thing comes on just clicks like a bad starter.. I thought it might be a battery only has 30k on it.
Please help.
Old Jun 11, 2022 | 09:17 PM
Cap77's Avatar
Cap77
Originally Posted by Jarhead71
I have a 03 ultra.
how old is the battery?
and have you checked all connections?
..L.T.A.
Old Jun 12, 2022 | 12:18 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Use a rubber mallet and wooden stick. Tap a few times on the end of the solenoid. Sometimes they stick.
johntaylorny
Mar 15, 2016 03:10 AM
kbob2000
Aug 18, 2012 04:11 PM
plumblocal1
Nov 23, 2008 11:56 AM
greezymonkee
EVO
Sep 13, 2007 04:32 PM
djprey
Jun 26, 2007 12:36 PM
