Need conformation please..
Old Mar 11, 2010 | 10:18 PM
Milty's Avatar
Milty
Default Need conformation please..
Powder coated my shift arm that couples to the linkage. Put it together tonite with a new shift arm and peg but it seems fck'ed up?
Now on the shift arm it has 2 o-rings and 1 rubber stop. When I put it back together I put 1 o-ring on the inside, 1 o-ring on the other side then the rubber bushing then my shift arm goes up to the rubber then voila done. It seems like it should have less side to side movement? Should I put another rubber or washer to eliminate the movement? Is this normal? Do you need to grease that shaft between the o-rings? Can't find my manual anywhere...
Old Mar 11, 2010 | 10:21 PM
DaveFLSTFB's Avatar
DaveFLSTFB
That seems right if I remember.
Old Mar 11, 2010 | 10:36 PM
Milty's Avatar
Milty
It seems a little sloppy, that shift arm should just move back and forth. Tell the truth I can't remember what it was like b4?
Old Mar 11, 2010 | 10:46 PM
DaveFLSTFB's Avatar
DaveFLSTFB
Yeah they are sloppy, I don't think there is much we can do about it though. I guess you could shim it if you want, but I don't think it is neccesary.
Dave
Old Mar 11, 2010 | 10:49 PM
Milty's Avatar
Milty
What about grease? That shaft must need to be lubed?
Old Mar 11, 2010 | 11:15 PM
DaveFLSTFB's Avatar
DaveFLSTFB
I just used some never seize on mine
Old Mar 11, 2010 | 11:19 PM
Milty's Avatar
Milty
Cool,
I am ready for this thread to die.
Old Mar 11, 2010 | 11:22 PM
DaveFLSTFB's Avatar
DaveFLSTFB
Done
Originally Posted by Milty
Cool,
mikebaby
Apr 29, 2018 09:35 PM
Alex E
Shovelhead
Dec 10, 2016 11:10 AM
jacknthebox
Jun 27, 2013 02:46 PM
Rnt77
Jun 17, 2013 07:18 PM
Jo3hughes
The General Motorcycle Forum
Mar 6, 2013 08:41 AM
