Fixing blinkers
Old Apr 17, 2010 | 04:56 PM
fstfrd01's Avatar
fstfrd01
1st Gear
Default Fixing blinkers
I was asked to see if i can fix the blinkers. Have the manual for the bike and i was starting with trying to take the tank off because there should be a module under there right? There is the odometer **** that should turn off but it just continues to rotate. Its not coming off.
anyone help me figure out how to get this off so i can see under it where the blinker module should be.
Old Apr 18, 2010 | 08:55 AM
fstfrd01's Avatar
fstfrd01
1st Gear
anyone for some help
Old Apr 18, 2010 | 09:50 AM
jneubig's Avatar
jneubig
What year and model bike ya working on? Are you talking about the console nut?
Old Apr 18, 2010 | 09:58 AM
fstfrd01's Avatar
fstfrd01
1st Gear
its a 99 heritage softail. In the manual its called a odometer **** and screw
Old Apr 18, 2010 | 12:21 PM
nomaster's Avatar
nomaster
maybe take the console off and hold the back side of the switch while you turn the button i may be confused as mine is an 07 but i thought the turn signal module was in front of the back tire behind the splash gaurd
Old Apr 19, 2010 | 08:24 AM
fstfrd01's Avatar
fstfrd01
1st Gear
thats the thing is this **** needs to be taken off before i can take the console off. But the **** just turns and doesnt unscrew.
Ill look where your blinker module is. I was just told it was under the gas tank.
Old Apr 19, 2010 | 09:51 AM
XARAN's Avatar
XARAN
It not under the gas tank on a 05, its in front of the rear tire flap.
What are your T / S doing ? I have had my T/s continue to flash fast and not cancel a couple of times. One time it was a bad ground at he battery to fram (small dia wires) and the other time a few weeks ago it was a bad bulb (was still working but dimmer than the rest) when I replaced it all is good. Start with the easy stuff, try replacing the bulbs 1 at a time first ,
Old Apr 19, 2010 | 02:33 PM
fstfrd01's Avatar
fstfrd01
1st Gear
Already tried new bulbs and still didnt work. The blinkers will not work at all. left or right.
DirtyBikeTrash
Electrical/Lighting/Alarm
Nov 25, 2014 08:38 PM
SouthernGent
Dec 8, 2012 09:24 AM
captain1more
Sep 23, 2010 02:19 PM
dammitimgumby
Aug 27, 2008 10:44 PM
daws567
Oct 26, 2006 01:20 AM
