Oil input
Old May 12, 2010 | 11:09 PM
casadelray's Avatar
casadelray
Default Oil input
Just did my first oil change over the weekend. Actually posted for tips and received many good ideas. But I thought the engine had a three qrt capacity? Am I wrong? I read someplace 3 qrts would be needed during re-servicing. Mine only took 2, and yes I let it drain for over an hour. Thoughts?
Old May 13, 2010 | 05:52 AM
jimmers1817's Avatar
jimmers1817
3 qts dry fill. 2.5 wet fill. check level on stand with engine hot.
Old May 13, 2010 | 06:56 AM
nikonf8's Avatar
nikonf8
Default Oil
Mine takes about 2.8 with filter change.proper procedure for oil change. run bike get it hot. drain oil remove filter pour some oil in new filter and replace. add oil about about 2.8 including the oil you put in the filter. Take the bike for a ride get hot. let idle for about two minutes shut down let oil drain a couple of minutes, check oil top off to fill when hot mark should only take about 2.8 total. There is always about 28 ounces in the sump that does not come out with an oil change total capacity for the bike is about four quarts counting the 28 in the sump.
Old May 13, 2010 | 07:25 AM
2kids3pets's Avatar
2kids3pets
Dry its 3+, you can't drain it completely, yes you leave a quart of used oil in there that's why I scavenge every change
Old May 13, 2010 | 08:40 AM
tk353's Avatar
tk353
cool color bike
mine takes 2.6 with filter change. warmed the bike and then drained the oil and then removed the messy filter and let that drain a little more. all done on the side stand but held the bike up and left and right to get the oil out of the drain.
Old May 13, 2010 | 06:18 PM
casadelray's Avatar
casadelray
Thanks all.
Bluraven
Sep 12, 2021 04:18 PM
sac130e
Aug 29, 2016 06:42 PM
Wakko47
May 3, 2012 07:24 PM
Rickr01
Aug 8, 2011 01:46 PM
maintainin
Oil Archive (no new posts)
Apr 13, 2009 06:26 AM
