Doing the big wiggle
Old Feb 23, 2011 | 05:57 PM
LocoPilot750's Avatar
LocoPilot750
Default Doing the big wiggle
It's been a couple of months since I've had a chance to get the Heritage out on the highway, but it got up to 65 deg here today. I rode into town, and was driving down the street about 40mph. Without much warning, the bike started to shift or wobble side to side, quickly, for about 30 or 40 feet, then stabilized. It felt like driving on a pressurized water hose laying length ways for a couple of seconds. After that, everything was back to normal. At first I thought I had a flat tire, but I must have run over a seam or crack running down the street. I never saw anything ahead or in the mirror, but it sure got my attention. The bike pre-flighted OK, and I looked it over when I got done for the day, everything's airworthy.
Old Feb 23, 2011 | 06:04 PM
KeeBee's Avatar
KeeBee
Flat spot on one of the tires from sitting for awhile possibly? They usually work themselves out. Just my guess.
Old Feb 23, 2011 | 06:45 PM
Tracker56's Avatar
Tracker56
Up here we have depressions in the pavement caused by the heavy logging trucks. You don't really see them until you in one. The bike gets kind or "squirrely" because the tires are trying ride out the rut in the pavement. It disappears as fast as it appears.
Old Feb 23, 2011 | 08:08 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It could be loose spokes, tire pressure, the pavement, any number of things. Also check that the pulley bolts are tight and the steering head bearings are tight.
Drew
Old Feb 23, 2011 | 09:00 PM
cpiad's Avatar
cpiad
Account Closed
Theres a patch of highway on my home that can make my fatboy behave that way....when they laid the road surface down they did it in two passes...and theres a joint in the middle....seems to grab the tire and the bike goes squirrely for about 40 ft....the geniuses that laid the road could have placed the seam on the passing line.....like they usually do....but nooooooo....they seamed it just where it would fuxx with bikes the most.
Just to be sure....lift the bike up....and make sure front suspension is squared away.
GoofySB
Aug 31, 2013 05:52 AM
Quadancer
The Dark Side
16
Jul 6, 2013 08:15 AM
combat_doc
Apr 8, 2013 02:53 PM
Prodaytrader
Jun 14, 2010 02:22 PM
wannabe
Nov 13, 2009 06:00 PM
