engine temp sensor
Old Apr 3, 2011 | 09:34 AM
mke125125's Avatar
mke125125
Default engine temp sensor
anybody know what this is or does? my 04 heritage is showing a code and the dealer said its the temp sensor. he also said 3 to 4 hundred bucks to fix
Old Apr 3, 2011 | 09:41 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It senses the temp of the engine. LOL. It is in one of the heads (I can't remember which right now) and unscrews. I have no idea if you can get it out without head removal but i would imagine you could. It should be on the left side of the bike kind of behind the horn if I remember correctly on my 4 hours of sleep. LOL. I hope this helps.
Drew
Old Apr 3, 2011 | 09:46 AM
mke125125's Avatar
mke125125
yeah, the senseing eng. temp is kind of obvious. but its an air cooled motor, it isnt like its gonna kick some fan on or something.
Old Apr 3, 2011 | 09:59 AM
Rakthi's Avatar
Rakthi
Simply put, the ECM needs this info to calculate the amount of fuel needed to inject into the engine.
When your engine is cold the ECM injects a bit more fuel (like having a choke) and then adjusts until the engine is up to temperature.
Looked it up in the 2007 service manaual and for the 07 bikes it's not that difficult to replace the sensor ... don't know if it is in the same position in the 04 bikes ... it's where Drew says it's supposed to be, on the back of the front cylincer and you can unscrew it after you take of the horn.
sensor part number is 32446-99, they cost around $40
You also have a sensor that checks the temperature of the air intake. That one a bit more complicated to replace ...
Old Apr 3, 2011 | 03:06 PM
cpiad's Avatar
cpiad
Account Closed
+ one ... get a shop manual .. replace it .. clear the code ... drive by the thieving stealership ... and feel goooooooood!
Old Apr 3, 2011 | 03:41 PM
slowhand's Avatar
slowhand
3-400 dollars for this is beyond ridiculous. It us a $30 part and a 5 minute replacement. You can get to it without removing anything. You'll just need a deep thin walled socket.
What a bunch of thieves.
Old Apr 3, 2011 | 04:51 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
i've read that if the engine temp reaches some threshold the ecm sends pulses to only one injector in an attempt to lower temps...i would advise to check for codes yourself, if some come up write'em down and clear'em, go for a ride a see if the engine light turns on again, if it does check codes again to see if they are the same...you'll find info here and the net on dtc's...hopefully you won't have to spend hundreds to replace a sensor...if used the attached steps to retrieve dtc's on my '07, might work in yours...
have you noticed any symptoms?
File Type: txt
Old Apr 3, 2011 | 05:25 PM
slowhand's Avatar
slowhand
If it is the ets, your motor will run like crap once it reaches operating temperature.
Old May 3, 2014 | 07:57 AM
DrTandem's Avatar
DrTandem
Stage IV
I know I'm late to this thread, but I just experienced this problem on my fuel injected '04 Heritage. The symptoms were similar to bad gas; stalling when first starting and running really rough after warming up and the check engine light illuminated. As another posted, it's just a $40 dollar part. On my bike, it is on the left side of the bike behind the horn. The engine code for this problem is PO118. To look for the code, with the bike off, turn the Off/Run switch to run, hold in the odometer button and turn the switch to Ignition. You will see the speedometer sweep and then a message saying "Diag." Release the odometer button and press it once quickly. You will see a code flashing, click the odometer button once again quickly and the trouble code, if any, will appear.
If it's the engine temperature sensor, it is easy to replace and takes about 15 minutes. You'll need a deep 3/4" socket for the sensor and a 1/2" socket to remove the horn. Remove the horn and carefully let it dangle, if you don't want to unplug it. Next, pull up the boot covering the sensor wiring. (The sensor is screwed into the block) Unplugged the wiring carefully by gently rocking it back and forth while pulling. Then put your 3/4" socket over the sensor, then put the socket wrench on the socket. It's a tight fit. Once you have it loose, remove the wrench and socket and finish unscrewing by hand. Install the new sensor by hand being careful not to cross-thread the brass fitting. Then finish with the wrench and put it all back together in the reverse order of how you removed it. You can clear the code by holding the odometer button while the code is being displayed.
Old Oct 20, 2015 | 07:17 PM
doug62's Avatar
doug62
Thanks for the instructions
