How to loosen rear tank bolt? 08 Rocker
Old 04-04-2011, 05:44 PM
thosehawks's Avatar
thosehawks
thosehawks is offline
Default How to loosen rear tank bolt? 08 Rocker
So I am trying to install the 2" lift kit on my 08 Rocker and I can't figure out how to loosen the rear tank bolt. I have taken off the seat and believe I can see the bolt I am trying to get to, but there is no room for a wrench to get to it. Alot of people have done this, but I am obviously missing something here.
Anybody able to tell what how to get it loosened?
Old 04-04-2011, 05:54 PM
SMH's Avatar
SMH
SMH is offline
Pretty sure it took a boxed end to get mine off. Couldn't get a socket to fit.
Old 04-04-2011, 06:10 PM
oct1949's Avatar
oct1949
oct1949 is offline
We all dont have Rocks...
A pic would be nice to see.
Old 04-04-2011, 07:45 PM
Fogle's Avatar
Fogle
Fogle is offline
I had to use the open-end of the wrench. The nut will slide against the tank ever so slightly but it will turn. Kind of goofy.
Old 04-04-2011, 07:53 PM
kkiley's Avatar
kkiley
kkiley is offline
Must be a totally different setup than my FB...wish I could help
Old 04-04-2011, 08:01 PM
thosehawks's Avatar
thosehawks
So here are a couple of pics w/ the seat off. I am assuming the nut/bolt I want to get to is inside what I would call the top tube. You can see the bottom of the threads hanging down inside that tube. The problem is that there is almost no space between the nut and the tube to get a wrench.
Does the gray piece on top of the tank need to come off to get access to that or am I completely wrong on where the rear bolt is located?
Attached Thumbnails How to loosen rear tank bolt? 08 Rocker-dsc_2045.jpg   How to loosen rear tank bolt? 08 Rocker-dsc_2046.jpg
Old 04-04-2011, 08:06 PM
thosehawks's Avatar
thosehawks
The nut visible on top of the tank only appears to attach the gray piece to the top of the tank.
Old 04-04-2011, 08:15 PM
pontoonman's Avatar
pontoonman
pontoonman is offline
That is the nut you want to turn. You can get it with an open end wrench.
Old 04-04-2011, 08:59 PM
rubiconMike's Avatar
rubiconMike
rubiconMike is offline
+1 It's weird but you can get it with the open end wrench. Don't worry, you're not going to scratch that gray power coating.
Old 04-04-2011, 09:20 PM
thosehawks's Avatar
thosehawks
So are you guys saying it is the nut on top of the gray powder coated piece or inside the top tube?
Quick Reply: How to loosen rear tank bolt? 08 Rocker
