help with exhaust!!!
So I have a 2010 Rocker, looking to replace the stock exhaust. Besides the pipes, what else do I need to order? do I NEED a new intake and a fuelpak??? WIll the bike run fine with just the new pipes? please help me! thanks
All depends who you talk to. I agree you'd probably be fine with just pipes. I ran some slipons for a year with no tune, but don't forget the bikes are pretty lean to start with, so new pipes wont help that problem...
In my experience just adding slip on mufflers will not be a problem with the stock ECM. Now if you change out the pipes ie. (from the exhaust ports back) you will need to have your ECM remapped or add a fuel management system such as a Power Commander V , Fuelpak or other tuner. I did a full set of pipes and my bike would have really bad decel popping and would hesitate while under light throttle and steady speed. I called Fuelmoto ordered their Stage 1 A/C and Power Commander V and the bike runs great.
BYEOFCR
Mar 17, 2011 02:35 AM
