Triple headlights for a Softail standard
i have kuryaykn lights on my 03 standard there not on a bar they clamp on your forks they look nice on the standard as it has the smaller ft end compared to the fatboys or other models with the bigger light and fork set up
they are smaller then say the stock harley style light bar style
this is the best picture i have on my computer
I bought this kit from Ebay, the link below is just to show you what it is, search around and be patient and you'll find it for 100 bucks or so. They make another kit to mount the blinkers under the lamps, it's about 40 bucks. Lamp kit came with everything you need including relay and waterproof switch. I also got a used 7.5" Fatboy headlight, that not only looked better but with all three on night riding is much better..I can post a pic if you are interested, I'll have to go take one.
http://cgi.ebay.com/ebaymotors/HARLE...item2a0f76feba
D
D
D
D
Hey Doug,
I hate to make you do some work but if you could take a picture that would be great. This kit looks to be what ive been searching for. Ive been looking at a 7" headlight but am glad to know that a 7.5 will fit. How was the installtion for the whole set up?
Thanks!
Thanks!
D
D
Some pics for ya, I did not use the HD blinker relocation kit I mentioned above, I already had them mounted to the forks so I just moved them down below the tripple tree...looks good in person..
The instructions wanted you to have them only work when the highbeams were in use but I just re-routed the positive wire to the ignition switch and I can use them Hi or low beam- I like to run them when on the highway, day or night.... I can't find the pic of the switch, it mounts to one of the screws that hold the clutch lever housing to the bars, very handy. Installation was a snap and I'm real **** about things so If I did it quick then you know it's easy.. That's it, hopes this helps.
D
D
