Rocker Pegs?
I'm curious as to why it says in the HD Accessory Catalog that none of the pegs will fit the rider position on the FXCW/C. My local HD parts lady told me it was because the Rockers have a kink in the pegs that give them more ground clearance because of their low stance. This makes no sense to me, because the kink in the peg positions it about 3/4" back and down, closer to the ground. Has anyone had issues with using aftermarket HD pegs on their Rocker anyways?
My stock rocker pegs were straight... no kinks or bends in the passenger pegs. The front pegs were off-set.
I replaced them with straight pegs.
Thanks guys. Offset would have been the proper word to use, its not as if they are bent or kinked. The only thing I can think of is that they are offset for boot clearance and comfort, more so when shifting up.
harley flame pegs on mine, someone is pulling your string (or maybe they just dont know).
pull the e-clip, pull the pin, pit it in the new pegs, put in e-clips, done, loosen the shcs (allen) in the end and swivel them to the position you want.
Pat in tennessee
Pat in tennessee
