I was wondering what piont and time that you need to replace your rotor. Sad but true , I have let my pads wear down too far,(I think). I have had a little metal to metal sound for a few weeks now. Will a new set of pads do the job or should I just go ahead and buy a new rotor?
get a pic of your rotor if possible, could possibly have it turned and smoothed out but i'm not positive on thickness for a bike rotor, cars can be turned several times
If it's the stock rotors, I think the Min. thickness is stamped right on them? As long as there is no major grooving, just measure and compare to minimum.
If you need new ones, and are just looking to stay stock, ebay is a great place for slightly used takeoffs for cheap.
I talked to the local Harley dealership and they told me that you do not turn down a rotor on a bike. The thickness WAS stamped right on the rotor itself (thanks JREICHART), It was .180, I measured mine and it was .184. So I bought a new rotor and pads. This will be my Saturday project. Does anyone have any tips or tricks to this, or is it as simple as it looks?
+1 here. This has always been the general consensus. The rotor on a bike is way too thin to have turned down. Even if it just needs cleaned up a little, it will wind up warping in no time. Look at the difference between a set of auto rotors and bike rotors and bike rotors get just as hot. This is a good excuse to get the nice set of floaters that you've been looking at.
And yes, it's as simple as it looks. Loctite on the bolts, torque them down in incremental sequence like you would head bolts. Don't set the wheel down with your new rotor on it face down, it doesn't take a lot to bend the rotor.
