Wheel Differences
Old Dec 7, 2011 | 11:56 AM
bpope's Avatar
bpope
Default Wheel Differences
Have kind of a technical question. What is the difference in a 21" spoked wheel off of a softail standard from 2005 and one from 07 up? I know the bearings are different...but the actual wheel themselves, are they different? What would the differences be?
Reason being and example...if I find an '08 wheel from a night train to put on my '06 deluxe - would it be as simple as only changing the bearings?
Old Dec 7, 2011 | 01:02 PM
jakazz's Avatar
jakazz
I believe that the only diff is profile and non profile rims, profiled rims are a smpooth curve on top and the non are stepped..... if thats what you want to call it.
Profiles look better to me, where as the non look the same as all spoked rims looked since the 60's
STEPPED
PROFILE
Old Dec 7, 2011 | 01:13 PM
bpope's Avatar
bpope
Oh really? OK, well that kind of makes sense. The thing that had me wondering is the two part numbers below.
44608-05A - Which is a Profile Rim for 00-06 Night Train
44608-08 Profile Rim for 07 up.
I wondered if the only difference is the bearings...but then again, Harley doesn't sell this wheel with bearings installed - so that is what made me wonder if there were other differences??
Thanks for the help...yes, the Profiles look better and will match my Profiled Deluxe wheel better too!
Old Dec 7, 2011 | 01:15 PM
kozy22's Avatar
kozy22
The inside axle is different too. Found that out when I swapped mine. All I did was change the bearing and used the axle from my stock wheel. 07 and up bearings are narrow the other ones fat
Old Dec 7, 2011 | 01:43 PM
bpope's Avatar
bpope
Don't mean to be ignorant...but what do you mean by the inside axle?
Old Dec 7, 2011 | 02:41 PM
kozy22's Avatar
kozy22
Inside the wheel, between the two bearings is a metal rod/ tube (maybe axle goes through it)
http://images.search.yahoo.com/image...mb=VMzwoNBfK9D
I'm talking about the small tube on left next to bearing (think it reads 92152)
Old Dec 7, 2011 | 02:53 PM
bpope's Avatar
bpope
Oh, OK I got you. That is cool...thanks for the diagram. If I can find a wheel at a killer deal from an 07 up, I still think I can get it to work cheaper than buying a new one for a 00-06. Thanks everyone for the help.
Old Dec 7, 2011 | 04:08 PM
kozy22's Avatar
kozy22
I'd buy the right one if I were you for two reasons
1. The skinny wheel and tire looks odd under the fender
2. A lot of people have had issues with not being centered in the fender
Old Dec 7, 2011 | 04:26 PM
bpope's Avatar
bpope
Right one being the 3" or 3.5" wide one? I have seen some that had the 2.15" wheel like Malingerer and a few others and I didn't think it looked bad?
Old Dec 7, 2011 | 04:48 PM
Motown Strag's Avatar
Motown Strag
I love the true SoCal Viclas that run those skinny wheels...bikes like that set the trend but it does kind of look like a Schwinn wheel under that big fender.
Not trying to dis
