wider front tire on softail standard ?
Old Jul 26, 2005 | 08:46 PM
hunter93's Avatar
hunter93
Default wider front tire on softail standard ?
I'd like to change my front tire on my softail standard to a wider front tire. Does anybody know if I can do that and what size tire I can change to? Do I have to change the forks, or does a wider rim/tire fit in my current fork. Has anyone changed to a wider tire?
Old Jul 26, 2005 | 09:18 PM
jhnmflr's Avatar
jhnmflr
Default RE: wider front tire on softail standard ?
I can't really help , but would think that there is plenty of room to do it . It would be a good look though .
Old Jul 27, 2005 | 03:32 PM
HDWRENCH's Avatar
HDWRENCH
you have to 90 now to go to the 110 you need a new front fender. I have done several and they handle much better feel more stable under low speed, and loose traction type riding( gravel parking lot) Fenders are not to badley priced. There is a 100 tire but it really does not make any improvment. For the wider 21 the 110 is a great way to go. BUt you also need a wider front rim, you can get the 110 on a stock wheel but it is wash as the tire gets pulled into the bead and is really not any wider.
Old Dec 13, 2007 | 03:45 AM
The_Snowman's Avatar
The_Snowman
So tell me if I can do this ??? I have a 2004 Softail Standard, I would like to fit a 2007 Fatboy wheel, you know the one with those holes all around? and upgrade to 1" axle at the same time.
Can I just buysay, the 2006 lowers (I believe that was first year of 1" axle, probably same part number for 2007 unless they changed something again), a 1"axle, a wheel of course, any stock spacers, new fender also, did I miss anything?
I guess this hinges mainly on whether the fork spacing is the same for the Standard and the Fatboy?
Anybody seen this done, thanks, John
Old Dec 13, 2007 | 05:51 AM
Korbenw7p3c's Avatar
Korbenw7p3c
On a side note; wouldn't that throw off your speedo a bit?
Old Dec 13, 2007 | 05:57 AM
jimmyz's Avatar
jimmyz
[quote]ORIGINAL: Korbenw7p3c
[/qu
Unless it's an older softail the speedo is run from a speed sensor.
Old Dec 13, 2007 | 10:37 AM
agapsdiver's Avatar
agapsdiver
If you want to go to a 16" wheel, like Fatboy/Heritage, you can check out my conversion here:
https://www.hdforums.com/m.asp?m=907...age=27&key=
If you want to stick to a 21" wheel with a wider tire I can't help you.
Old Dec 13, 2007 | 11:20 AM
agapsdiver's Avatar
agapsdiver
Default RE: For "The_Snowman": wider front tire on softail standard ?
ORIGINAL: The_Snowman
No need to go to a 1" axle and extra cost of buying new lowers for your forks.... buy an earlier model Fatboy wheel with a 3/4" axle...HD dealers should still sale them and I'm sure there's lots of used ones around...If you have to get a 2007 Fatboy wheel you can change out the 1" axle with a 3/4" installation kit...
...ps..plenty of space for a Fatboy tire/wheelwith a Standard
Forks...did it with my Night Train.
Old Dec 13, 2007 | 02:07 PM
andycg's Avatar
andycg
fat front is the only way to go[sm=trust_me.gif] my post here
Old Dec 13, 2007 | 04:16 PM
grimm's Avatar
grimm
fat's where it's at, baby.....
[IMG]local://upfiles/860/DD3C3F5FB2214BB8A54AB7AD4BA10F2D.jpg[/IMG]
goblue90
Jul 10, 2018 11:06 AM
Dizzyboat1
Oct 22, 2015 03:05 PM
dmact
May 17, 2010 12:25 AM
John Bernard
Sep 7, 2009 08:03 PM
hunter93
Jul 21, 2005 10:15 PM
