pulled the trigger
Old Mar 18, 2012 | 12:45 AM
outkastkustumz's Avatar
outkastkustumz
Default pulled the trigger
well with the bike being about 80% back together and the tins out getting painted i couldn't make myself put that goofy lever thingy back on the left handlebar,,,, quick trip to la briola's website and my suicide jockey shift kit is on the way..... any body else run one of these with the standard shift lever they send? like to see some pics of one on a bike,, i got an 09 rocker,, hopin it works out alright
Attached Thumbnails pulled the trigger-425237_10150670797394730_734054729_9084794_626916366_n.jpg
Old Mar 18, 2012 | 06:01 AM
jreichart's Avatar
jreichart
You'll love it, takes some getting used to but it's worth it. I did a home made jobby on mine using an Exile cable and a shift arm I got on ebay for cheap. Had to cut apart the arm so I could position it where I wanted, and fabbing all the brackets for the cable wasn't easy, but it works! Here's a few pics:
Here's the pedal setup before PC. That plate is the controls extension that I made, and yes it got trimmed before PC
And here she is all finished up
Old Mar 18, 2012 | 08:01 PM
outkastkustumz
is that the same way that labriola has there's set up? from the few pics that i've seen it looks like the cable comes in from the front and must wrap a drum to pull the cable when the pedal is pushed,,, yours looks good bro,, better than i think it'd look with the cable from the front...
Old Mar 18, 2012 | 08:34 PM
SprungDave's Avatar
SprungDave
It will be a different/fun riding experience. Bottom line: if you don't love it, you can return it to the stock configuration. Enjoy!!
Old Mar 19, 2012 | 06:48 AM
JakesDad1's Avatar
JakesDad1
Steep learning curve, but after a bunch of miles its easy. I used the Labrioa clutch but fabed my own jockey shift.
Early in the "learning curve" I thought I had made a mistake, and was cursing my stupidity for making this mod. But since I was on a long trip (5,000 miles to Sturgis), I just had to live with it until I got home. By the time I was home, I was comfortable with it! Go figure! The only reason to do this mod is "because its cool!". Going through the gears is a slower, methodical process, where as before I could just jam my way through the gears. Much more relaxed way to ride. I love it NOW.
Old Mar 19, 2012 | 10:04 PM
outkastkustumz
thanks for the pics guys.... cant wait to get this on the road
jreichart
Feb 8, 2017 08:15 AM
Redbeard719
Jul 14, 2012 06:22 PM
lowlife801
Shovelhead
May 3, 2010 05:49 PM
ao2slabaugh
Mar 24, 2010 11:49 PM
Skinner
Ironhead
Mar 3, 2008 06:26 PM
