Probably a dumb question, but...
Thanks Liberator, I'll see what I can scare up from Clymer (forgot all about them...)
Post your setup (pipes, AC) and we can help you better. If you don't know post some pics.
There are better explanations of this procedure out there. This goes over the basics:
http://forum.highlifter.com/Basic-CV...-m1872049.aspx
Harley Dude - thanks a ton. Great info for me (bike veteran, Harley newbie).
Long story on the scoot, but it has an unknown aftermarket 2-1 It is fairly mellow tone so I assume some baffling. K&N filter and as near as I can tell an after market backing plate.
No idea what else is going on inside the motor. I have been taking care of lots and lots of bone-head "work" (handling was a bit squirrely, found no bearing adjust nut under top triple tree - only thing holding the front end together was the the fork stem nut on top of the triple tree...).
Anyway, thanks for the great information. I am planning on removing both tanks tomorrow (new mount bushings going on) so I will either pop the carb off or at least get the float bowl off and see what jets are installed.
I just ordered James rebuild kit,185, 180, 175 mains, 40, 42 pilots. Perhaps one of the previous owners got micro-drill happy and hacked one or both of the jets out...
Past the basic rebuild and mucking with jets, any other suspect parts in the carb to look at?
Thanks.
ps - plugs are stock harley 5R6A - any recommendations to try a hotter plug?
Pull the idle mixture screw all the way out. There is a rubber o-ring or should be an o-ring on needle itself. If that is missing or torn that may be causing your problem. I have heard of it happening. Also pull the slide out of the top and inspect the rubber on the vacuum slide. The slide should not cause any idle problems but it is something you want to check. When you put the slide back in make sure that the rubber lines up in the slots of the carb body and CAREFULLY put the top cover back on. Also pull the main jet and emulsion tube out and pull the needle jet out and clean all that area up.
One last thing as far as the int. jet goes I would start with a .45 at least. They come with a .42 from the factory but this is always to lean. But first I would figure out why you are getting such a rich condition with that .42 and the idle mixture all the way in.
If you need a schematic this site may help you out as far as understanding where everything is at.
http://dudeworld.com.au/ARTICVCARB.HTML
http://dl.dropbox.com/u/45931257/99%...n/GEDC0191.JPG
