Crank positoning sensor
Old Jul 25, 2012 | 11:57 PM
shwnoff1's Avatar
shwnoff1
Default Crank positoning sensor
I have a 2008 heritage that has starting issues. Some time it starts fine other time it starts like it is running on wrong cyclinder.If I shut it off and do it again it might fire right.I was told at my dealer that the crank sensor is going bad.Anybody had this problem or any ideas before I start spending money on stupid things. Also there is no check engine light on.
Old Jul 26, 2012 | 07:19 AM
cwsharp's Avatar
cwsharp
Hard to say from only that information. It's not a big deal change that you can do yourself more than likely if you want to use the hit and hope method. Otherwise you have to test the sensor output when the bike is being turned over to make sure that the proper signal is being sent every time. You will need a shop manual.
C#
Ultra RB
Apr 1, 2016 10:01 PM
Casting Crowns
Feb 27, 2013 08:36 PM
jb bill
Exhaust System Topics
Mar 18, 2010 07:19 PM
F1J1
Oct 22, 2008 05:20 PM
al704
Aug 31, 2007 08:10 PM
