What intake to buy????
So i just picked up my new programer at a sturgis sale at my local HD dealer, but i want to put a new air cleaner on it before it goes in and gets strapped to the dyno, i just don't want a nice piece to look at i want to know which ones are the best performance wise. the bike is all stock except V&H's pipes
Year and model? What do you plan on doing going forward? Big bore? Intake and pipes only?
Lots of variables, but just about anything will flow better than what comes on them stock, and the throttle body, manifold and heads are the real limiting forces here. The Screamin Eagle Heavy Breather is sposed to be a good unit, Arlen Ness Big Sucker, FuelMoto, The list goes on.
Received 3,963 Likes
For performance it is going to be hard to do better than an OUTLAW HiFlow 587.
Almost all after market A/C's are feeding the hot oily air back into the intake. You motor will perform best with cold, dry air.
Plus that oily air will eventually build up carbon on your piston, changing your compression and your tune will no longer be correct.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
Year and model for starts would help us formulate an informed opinion.
jla: See above. But I am no expert by any stretch the imagination. Did you have head work done when you did your build?
And Kevin at DKCustom: No offense for not putting your product with the others in my previous post. I am running your exhaust inserts.
I am no expert either nor do I want to put down anyones product but a question for DKCustoms, what makes that AC better than any other. I have a similar one on my bike form HD that I don't particularly care for, looks mostly. The other is the element is not open except to the hot engine. To me something like the SE or similar open forward type of AC's would be better. I just found a Performance Machine FASTAir AC that suits my fancy and to me looks like it would perform great. I used to drag race and think about forced induction with M/C AC's.
