Problem with Iridium plugs
Old Mar 23, 2013 | 07:58 AM
edpnjax's Avatar
edpnjax
Hmmm, interesting subject. Here is a Q&A off of NGK's site, note the part I bolded. Do what you want, but the gap needs to be checked (properly) in my opinion and it seems NGK agrees.
Here is the NGK site: http://www.ngksparkplugs.com/tech_su.../faqpregap.asp
Q: Do I need to set the "gap" when installing a new set of plugs?
A: Maybe. A spark plug part number might fit hundreds of different engines from many different manufacturers. Although the NGK factory will set the gap to a pre-selected setting, this may not be the right gap for your particular engine. The incorrect plug gap for your engine can contribute to a high rate of misfires, loss of power, plug fouling, poor fuel economy, and accelerated plug wear. It is always best to check the gap against the manufacturer's specifications. If adjusting the gap on fine wire or precious metal plugs such as platinum or iridium be very careful not to apply any pressure or prying force to the fine wire center electrode or insulator as they can be damaged. The gap should be adjusted by only moving the ground electrode.
Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
If you have any questions, please contact the NGK Sparkplugs Tech Staff
Old Mar 23, 2013 | 08:40 AM
Raccerx67's Avatar
Raccerx67
Originally Posted by Gunnerthedog
I've installed hundreds of Iridium plugs and never gapped them. They even tell you not to because of electrode damage.
Iridium plugs are also intended for high output coil on plug and SPFI fuel systems. It only takes a little bit of excess unburned gas to make them miss.
And once the plug starts missing throw it away.
I agree, GM and FORD even have service bulletins specifically saying not to gap these plugs are it will do damage to them. they tend to run a smaller gap than a stock platinum plug. Example on GM the platinum spec will be .060 and iridium will be pre gapped at .045 and meant to be left that way.
If you gapped the new plugs to a larger than preset spec, that could have damaged or the wider gap be the cause of your missfire.
Old Mar 23, 2013 | 09:00 AM
spydyr's Avatar
spydyr
I've had iridiums in both my bikes for 2 & 4 years now... no issues.
Old Mar 23, 2013 | 10:26 AM
SanJuanRon's Avatar
SanJuanRon
I have NGK Iridium IX on all my bikes and never had an issue. Also never gapped the new plugs. SJ Ron
Old Mar 23, 2013 | 11:44 AM
Surfbum's Avatar
Surfbum
I will check the gap. They look like they are getting really hot..bluish color.
My bike runs good on regular old champions, it gotta be something with these plugs.
Checking the gap today.
Old Mar 23, 2013 | 12:08 PM
Surfbum's Avatar
Surfbum
I will check the gap. But, I am just gonna go with champions on this bike. I have never had problems with Iridium plugs other than on this bike.
Old Mar 23, 2013 | 03:50 PM
TheTroupe's Avatar
TheTroupe
What he said....
No Problems
Old Mar 23, 2013 | 04:11 PM
checkers's Avatar
checkers
Originally Posted by Surfbum
I put some Iridium plugs in my 94 springer and it ran rough. It even seemed to miss on acceleration every now and then.
I put my old plugs back in and it runs great
Has anyone had this problem before?
Many posts on this. Most stating they ran well on stock HD plugs, about $6 a piece. Installed the plugs you mentioned or another exotic brand with 3 point electrodes etc. Most ran like crap. They reinstalled a pr of stock plugs and ran good. I dont see a reason to spend triple money on something that screws up the way a bike runs.
Old Mar 23, 2013 | 06:27 PM
whitemule's Avatar
whitemule
for what its worth no plugs are pre gaped for and bike or car would never install plugs until gap is checked
Old Mar 23, 2013 | 10:25 PM
Harleyboyddk's Avatar
Harleyboyddk
Running Iridiums for the past 5 years, no issues.
