I need some help with High Beam indicator lamp
A little background first. The bike is a 2012 Fat Boy Lo. I installed a Trucklite Phase 7 LED headlight and passing lamps set about two or three weeks ago. About a week ago I installed the module from HD allowing me to run the passing lamps and high beam at the same time. Starting this morning the high beam indicator no longer works. The headlight and passing lamps work fine, both high and lo beams but the indicator on the dash doesn't work. I'm not really sure where to start with this and I'm hoping it's as simple as a blown bulb but I'd really appreciate some insight into what it could be. Particulary since I didn't have a dealer install HD's LED's so I'm not confident I'll get much help from there.
Fat Bob, since the last thing you did was plug-in that module I'd take it out and put it back to the original's way it was. If you haven't already done so get a tube of dielectric grease and slaps him on all your connections before you plug them in ill health in the future.
