Which A/C to get?
Old May 11, 2013 | 06:10 PM
Bone Doc's Avatar
Bone Doc
Originally Posted by 06fxsti
how do you go about doing that to the stock cover?
Please take this as it is intended; a simple FYI. When you post something, like above, there is no way of knowing which post you are referring to. Your post doesn't always end up immediately after the one you are referencing.
At the bottom right of each post are 3 buttons:
1. Reply With Quote
2. Multi-Quote This Message
3. Quick reply to this message
If you select 1 or 3 or select 2 (on one or more posts) and then New Reply, the post(s) you are referencing will appear at the top of your post. This makes it easier for others to help you so we don't have to review previous posts, especially if it is on a different page. This is good practice even if it may be obvious what you are referring to. That way there is no question.
In this particular case you are probably asking about Hoggy's A/C cover since his was the only picture shown but that isn't always the case.
Old May 11, 2013 | 06:40 PM
N2STUFF's Avatar
N2STUFF
Originally Posted by soft 02
Can you post a link to this stainless filter?
It's in the pull down menu as a option for the A/C.
Old May 11, 2013 | 08:01 PM
dfndr's Avatar
dfndr
Thanks. Always wondered how this worked.
1. Reply With Quote
Old May 12, 2013 | 03:52 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Originally Posted by Arrogant Bastard
I really dig the look you have there. I have wanted to do that to the stock football cover but have no clue how to go about it. If you don't mind me asking, how did you do that? I would be scared to do it myself. Is there anyone that sells cover like that?
Here ya go!
Old May 12, 2013 | 12:27 PM
Das_Fatboy's Avatar
Das_Fatboy
Originally Posted by HoggyMtnBreakdown
Here ya go!
The only thing I would recommend doing different than what is in that write up, is to remove the outside ring before you cut it. If you slip one time with the dremel (or whatever you use to cut it) the ring will be ruined. Another reason I did it that way is even if you over cut the cover, the ring will hide any mistakes when you put it back together, I used a hair dryer to gently (I used tooth picks to pry it off) remove it and then when I was all done with the cutting, I re-applied it with some 3M double sided tape.
My SE stage 1 with modified football cover...
Old May 12, 2013 | 03:02 PM
Arrogant Bastard's Avatar
Arrogant Bastard
Hoggy, thanks for the info. That was a really good write up. Unfortunately that procedure seems to be a bit outside of my skill level. I'm sure I'd fork something up. And with this project it's pretty much a one shot deal, no second chances.
And Das Fatboy, that cover looks really nice. Looks like a professional job. I just with I could find someone or somewhere that sells them already made like that.
Old May 12, 2013 | 05:47 PM
HoggyMtnBreakdown
Dude, find a friend with the tools (and the skill) and have him help you. That's basically what I did. It's really not as hard as it looks...
Old May 13, 2013 | 01:26 AM
504ENGINEER's Avatar
504ENGINEER
Modifying the stock football and pairing it with the SE stage I A/C kit is the the least expensive and imho the best looking way to go...
Very nice...I wonder if anybody has done this with the 103? Meaning still using a 12 gauge wire for the template.
Old May 13, 2013 | 05:55 AM
HoggyMtnBreakdown
Are the 103 a/c covers different?
Old May 13, 2013 | 08:38 AM
Knucky's Avatar
Knucky
I have the AN Big Sucker stage 1, but if I had to do it over I'd get the stage 2 or derby sucker kit - lots more choices in covers and better airflow for not much more cost.
CB Cornbread
Feb 11, 2015 06:17 AM
Mason34
Mar 18, 2014 10:45 PM
rparnel1
Exhaust System Topics
Nov 17, 2006 01:27 AM
deuce31
Jul 10, 2006 01:41 PM
HDspringer
Sep 28, 2005 11:30 PM
