Little help
Old Jun 19, 2013 | 09:07 AM
Zambo5000's Avatar
Zambo5000
Default Little help
Can some one please help me. I am fairly new to HD. Last year I purchased an 05 Softail Springer. I usually let the shop do all my maintenance on my old Honda but I was feeling a little frisky and decided to change the fluid in my bike on my own. I was wondering what this plug goes to.
I took this plug out thinking it was the drain for the primary case. (I know, stupid) Anyway, a small amount of oil came out, I replaced the plug but was not sure where this gets refilled or if the engine oil will make it there. Help, Please!
Old Jun 19, 2013 | 11:10 AM
hspring03's Avatar
hspring03
Crankcase drain.... Not supposed to remove....
You'll be fine. Oil finds it way back.
Old Jun 19, 2013 | 11:15 AM
XARAN's Avatar
XARAN
Sump drain plug. It is pipe thread. Dont remove it, some people run into cracking the engine cases removing or installing it.
Its used to check for sumping, if there is an oil pump or valve problem.
Get a manual, most stuff on your bike is very easy to do and can save you a lot of $, but one uninformed mistake like removing and replaceing the pipe plug,overtightening it and cracking the crankcase will cost you hundreds or thousands.
Old Jun 19, 2013 | 11:22 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The drain plus is on the frame. Follow the hose out of teh bottom of the oil tank. You are far from teh first to do this. Manual is well worth it's weight in gold.
Old Jun 19, 2013 | 11:24 AM
Zambo5000's Avatar
Zambo5000
Thanks guys, I'll never do that again.
petdoc94
Oil Archive (no new posts)
33
Sep 7, 2020 07:34 AM
RadarRider
Jan 12, 2014 08:46 PM
Beerninja
Oct 3, 2009 07:11 PM
yzag
Exhaust System Topics
Jan 6, 2008 07:11 PM
Brettsterhog
Jul 23, 2006 12:18 PM
