Hd crossbones pegs and forward controls
Old Jul 15, 2013 | 06:44 PM
Hdmississippi's Avatar
Hdmississippi
6th Gear
Default Hd crossbones pegs and forward controls
Hi i have an 08 hd crossbones. I bought a set of pegs and forward controls. Opened the box and saw i needed a different kickstand. I m not sure where to start looking. Also these were for a 2000-13 softtail. Will they work?
Old Jul 15, 2013 | 09:12 PM
brettnbama's Avatar
brettnbama
What brand forwards? I used controls from a fx softail and kept my stock jiffy stand
Old Jul 16, 2013 | 12:30 AM
dproto09's Avatar
dproto09
I install Forward controls on my Softail Slim. Everything bolted right up. It a pain changing the rear brake cylinder, because you have to remove the brake lines and fluid drips all over the place.
Old Jul 16, 2013 | 11:34 AM
Hdmississippi
6th Gear
The forward controls set is from ebay. Black Billet Forward Controls
Fits Harley FXST Softail 2000-2013
5/8" Bore Master Cylinder
Billet Aluminum with powdercoat black finish.
Will theses work on my crossbones? Also what do i do about a kickstand? Thanks for Ll the help. Like i sed this is my first harley. I always had sport bikes.
Old Jul 16, 2013 | 01:38 PM
dproto09's Avatar
dproto09
I dunno, I installed the oem forward control. Everything fit. I'm not sure if I trust the no name band parts on ebay
Old Jul 16, 2013 | 01:59 PM
Hdmississippi
6th Gear
Well the shifter side bolted up no problems beside my kickstand is built into the floor board mounts. The bracket on the peg and shifter have 4 small threaded holes. I guess for a kickstand.
Old Jul 16, 2013 | 06:36 PM
brettnbama's Avatar
brettnbama
Your kickstand should unbolt. It is not built into the floorboard mounts
Old Jul 17, 2013 | 09:16 AM
Hdmississippi
6th Gear
Yea i can take the kickstand off but i need the mount to put kickstand onto the mount to peg bracket i think i found some mounts im going to order one and see if it works
ColoSpgsMark
Nov 28, 2009 02:25 PM
DW12
Jun 2, 2009 08:10 PM
gypsyrider52
Shovelhead
Jan 6, 2009 09:19 PM
weasel
Oct 29, 2006 12:08 PM
hd2000
Mar 13, 2006 01:50 PM
