I replaced my standard 2-up seat with a solo (since the Mrs can't ride due to back issues). Also removed the passenger foot-boards. Looking for a chrome cap to put over the pillar that the passenger foot-boards were mounted on. Any advice or suggestions? Thanks.
You can remove the bolt and either fill the threaded hole with a shorter button-head chrome bolt, or a black plastic plug. Either should be available at your local hardware store. Or you could dab some black paint onto a q-tip and paint the hole's treads (so rust will not set in) and just leave the holes open. I would go with either of the first two solutions...
