Hayden primary chain tensioner, comments?
Hayden
Good choice. I've used them on bikes for years from shovelheads to evos, to twin cams. Just put one on my 2011 Fatboy when I upgraded to a 124 engine and a Baker 7speed. I really think its much easier on primary chains and takes a lot of the jerk away when using big cams. On my old FXWG I think I'm on my third chain and it has over 130k on the clock. Don't think they were worn out but just changed them as a maintence item. When I bought my 7 speed from Baker I ordered one of their primary tensioners but wasn't real keen on they way they worked so went ahead and bought the Hayden which I should have done to start with from my history with them. Don't think you can go wrong.
Put one on my wife's lowrider after the stock tensioner overtightened and wiped out the IPB. Had an issue (noise) which Hayden promptly took care of on their dime. She says it shifts much better than before and she likes it a lot. I'll probably do this mod on my bike this winter.
I'm not trying be flip here. I just really want to know. IPB failure is common on a few years and models (including one I own), and an over-tightened chain is one theory, but I haven't seen anything which confirms that theory.
Son just had his IPB replaced at 23K on his 10 St.G.
Funny they said in some cases the MoCo secretly will warranty the 07's, 08's, 09's, and 11's.. but not the 10's..
The PHD master wrench at our dealership claimed that the failure is due to using GL (Son had 75-90 GL)in the tranny.
Stated, he is seeing more and more (15 or so this summer) failures by owners and that most all of them are using a GL in the tranny instead of any good syn 20-50 oil or Formula+.
I no longer have my heritage . I have a dyna now so I can save some weight . Dyna is fun but heritage is still my all time favorite motorcycle. On to the question at hand. I had a mechanic install a hayden m6 in my 2011 dyna as my primary chain tension was tight as a fiddle string. I have about 4.5 k miles on it so far and I really like it.
