Old 02-13-2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
  #7711
Old 02-24-2024, 09:01 AM
Aries Maniac's Avatar
Aries Maniac
Aries Maniac is offline
4th Gear
Originally Posted by Kidmandudebro
if you do a search on this site there is a fellow that will take your stock seat and make you whatever you really want. Have you tried gel inserts? Pillion seats for the passenger on breakouts are available or look for two up seats.
I use a Danny Gray solo Butt Crack and there is a passenger pillion they sell too.
I haven't tried gel inserts but the foreign bikes i use to own the mustang seat was really comfortable ill have to see what he can do thanks
  #7712
Old 02-24-2024, 01:03 PM
Road_King_Rider's Avatar
Road_King_Rider
Road_King_Rider is offline
I just took my OEM seat to a local upholstery shop and had them put in a gel pad and new foam shaped to my specs. I had the passenger pillion raised up for better back support and narrowed the nose for ease of putting my feet down and pushed back about an 1" because I'm 6'1". I did the same thing on my 14 SGS back in 2015 and I've kept that seat and it's now on my 21 RKS. I wholeheartedly believe in getting a seat customized to your needs instead of buying an aftermarket seat and hope it works out.
  #7713
Old 02-24-2024, 07:09 PM
Aries Maniac
4th Gear
Appreciate it I'll have to see what upholstery shops are around
The following 2 users liked this post by Aries Maniac:
Kidmandudebro (02-25-2024), Road_King_Rider (02-25-2024)
  #7714
Old 03-04-2024, 11:50 AM
JimGnitecki's Avatar
JimGnitecki
JimGnitecki is offline
This might be the ultimate Breakout engine guard!
It's by a place in Brazil apparently: Worldwide Wings Custom. That's TWO INCH diameter tubing, and apparently the workmanship is pretty exquisite. Given the weight of a more typical 1.25" tubing engine guard, this one must weigh about 20 lb I would estimate!
The retired police motorcycle officer who runs the "Preload" website got one and did a short video with it on his 2023 Breakout. It DOES look gorgeous in the video. But, very, very costly.
Jim G
The following 3 users liked this post by JimGnitecki:
Kidmandudebro (03-04-2024), Road_King_Rider (03-05-2024), vivid black (03-04-2024)
  #7715
Old 04-05-2024, 09:15 AM
Kidmandudebro's Avatar
Kidmandudebro
Kidmandudebro is offline
I got a custom made 2/up C&C seat coming in. Can’t wait to try it out, went with gator skin and gel inserts for both me and her. Also put in to have it set me back as far as possible over stock seat. I’m tall at 6’2” and so far I’m really digging the Danny Gray buttcrack.
  #7716
Old 04-09-2024, 02:00 AM
rodrocket's Avatar
rodrocket
rodrocket is offline
Originally Posted by Benjammin713
2013 IS 133T, thinking about doing the same, and wondering how much it moves it back.
40000001
REAR BELT, 133T, 24 MM WIDE (BLUE)
from what i am seeing with the 30 / 70 pulley swap going to 1 tooth longer on the belt its moved the wheel back around 8mm
Kidmandudebro (04-09-2024)
  #7717
Old 04-10-2024, 12:48 PM
24Breakout's Avatar
24Breakout
24Breakout is offline
Originally Posted by stratplexi
Agree with your assessment…bike handles fine and the suspension is fine. I was actually surprised at how comfortable the Breakout rides and how well it handles given the 34 degree rake and 240 rear. I believe Harley has engineered the chassis to get the best out of it despite the constraints for styling.
I'm a little late to the discussion, but I agree. I spent the last 17 yrs on a Suzuki M109R, which also has a 240 out back, a nearly identical wheelbase to the Breakout (the 109 is just over 1/2" longer according to the specs). It's not raked out as much, but is considerably heavier at ~ 760 lbs wet. I've had no problems with how the Breakout handles at all. It's actually a bit more nimble than I was expecting.
The following 3 users liked this post by 24Breakout:
Kidmandudebro (04-10-2024), PearNPie (04-13-2024), stratplexi (04-10-2024)
  #7718
Old 04-10-2024, 09:48 PM
JimGnitecki
On the 2023 and later Breakouts (the models with the 2018+ Softail frame), how are the passenger seat and the rear fender attached to the frame of the Breakout? Is it via those externally visible angled chrome pieces that also house the docking points, or is there other support not externally visible?
Jim G
  #7719
Old 04-11-2024, 09:15 AM
24Breakout's Avatar
24Breakout
Jim G
I haven't poked around enough underneath yet to comment on the fender itself, but on the '24 the passenger seat is secured by just a single screw at the back, smack in the middle of the fender. At the front of the passenger seat, the plastic baseplate has two grooves that slide under the mounting bolts that secure the rider seat.
  #7720
Old 04-11-2024, 09:19 AM
JimGnitecki
Originally Posted by 24Breakout
I haven't poked around enough underneath yet to comment on the fender itself, but on the '24 the passenger seat is secured by just a single screw at the back, smack in the middle of the fender. At the front of the passenger seat, the plastic baseplate has two grooves that slide under the mounting bolts that secure the driver seat.
Yes, I knew about the way the actual passenger pad is inserted and bolted, but I am wondering how the seat and the fender under it are structurally supported. I tried to look at photos and drawings of the 2018+ Softail frame, but none of theem show the fender and seat support system. They just show the triangulated single-shock swingarm, not anything else above it.
Jim G
Kidmandudebro (04-11-2024)
Quick Reply: The Everything Breakout Thread
