tube or tubeless
Old Mar 16, 2007 | 02:07 PM
ozzy07840's Avatar
ozzy07840
Default tube or tubeless
i just got a 2007 softail standard with the 200 rear tire and the 21 up front ,i think its running a tube in front with the spoked rim ,do you know if theres a tube in back with the 200 tire??
Old Mar 16, 2007 | 02:25 PM
seaflea's Avatar
seaflea
Default RE: tube or tubeless
I'm not positive, but I think the rear tire is tubeless. The front ahs a tube because of the spoke wheel. At least that is what I have read. : )
Old Mar 16, 2007 | 02:41 PM
recross's Avatar
recross
you are correct.......spokes=tube....mags=nope.....BC
Old Mar 16, 2007 | 10:12 PM
tony77's Avatar
tony77
well both my tires are spokes and it reads tubless on my tires ...2006 Heritage classic
Old Mar 16, 2007 | 11:16 PM
chivohead666's Avatar
chivohead666
My front spoke rim tire also reads tubeless yet it has a tube. tire can be used for both applications. but for spoke u need tubes. make sence?
Old Mar 17, 2007 | 12:50 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: tony77
That just means that the tire itself is rated, and can beused without a tube.
But no itre can be run tubeless on a spoke wheel because the spokes coming through the rim makes for a built in leak at every spoke hole.
Mag wheels on the other hand are solid and only have the one hole for the valve in them. So you can run a tire without a tube on them very easily.
Old Mar 17, 2007 | 01:14 AM
Littleshack's Avatar
Littleshack
There are Tubeless Spoke Rims Out there. But 99.9% you should have a tube in that tire.
Always one way to find out.
Old Mar 17, 2007 | 02:12 AM
cowboy Harry's Avatar
cowboy Harry
I want to see this.[8D]
ORIGINAL: Littleshack
Old Jul 13, 2008 | 08:42 AM
*JC*'s Avatar
*JC*
Yea, it's has a tube on the spoke wheel despite the tire being capable of being run tubeless. It's tubeless application is for non-spoke rims...
&nbsp\\;
But here's the clincher isn't the front tire 21" a biasply tire? And the rear 20055R17 tire a radial?
&nbsp\\;
Does anyone make a MH90-21 radial?
Old Jul 13, 2008 | 09:26 AM
128auto's Avatar
128auto
+1
Sproke wheels got to have tube, no matter what.
ORIGINAL: Citoriplus
That just means that the tire itself is rated, and can be used without a tube.
