Breakout owners with V&H Shortshots
My first post after joining and lurking for a few weeks, so here it goes. I'm looking at putting staggered black Shortshots on my '14 Breakout and was curious what part number I'll need? I'm aware V&H doesn't make them specifically for the Breakout but after reading some of the other posts about owners modifying the mounting holes to make them fit I think I'd like to give it a try. I did contact V&H about when Shortshots may be available and this was the response I got: "Good Afternoon,We do not have a release date for those pipes to come out for that bike. Any new information will be posted on our website."
Thanks,
Scott
Thanks,
Scott
I have V&H Big Shots Staggered on my m.y. 2014 BO and they weren't supposed to fit either. No issues with oil lines clearance and while installing them.
I guess you should look for 2012/14 Softail model fitting. I did the same.
Btw, Short Shots are nice but extremely loud and, imho, since BO has a long profile, maybe slightly longer pipes would match better your bike.
Thanks for the responses so far! Nostradamus74 I'm glad to hear fitment shouldn't be an issue. I'm hoping to bolt these up myself since the local H-D dealer wants $275-300 to do it. The savings will go towards a new air cleaner assembly. With one daughter in college and another living at home this is definitely a budget build.
I wanted the short shots on my BO really bad so I asked V&H about them. Here's their detailed response. I'm not getting them now.
Chris,
We do not make the Short Shots for the Breakout our only offering is the Big Radius 2-2. The pipes you are seeing on the Breakout are most likely H-D Softail Short Shots adapted to fit the Breakout. Even through the Breakout is technically a Softail it doe have it's own exhaust fitment due to the Large oil tank and wide swing arm. If you do put the Short Shots on a Breakout you will have to space the pipes away from the bike which will out the pipes in a bind and cause them to break over time.
Thank you,
Steve Darrow
Customer Service Supervisor
VANCE & HINES
13861 Rosecrans Ave. Santa Fe Springs, CA 90670
t. (562) 921-7461 f. (562) 802-0110
Chris,
Thank you,
Steve Darrow
VANCE & HINES
