Horn relocation/replacement ideas?
Old May 15, 2014 | 07:31 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by jreichart
If a vehicle cuts you off or places you in a bad situation and your first reaction is to go for the horn button and not the throttle or brake, then that horn will likely decide your fate.
Why choose between the horn, throttle and brake? You can't do two or three driving functions at the same time?
Don't know about you, but even my ol' lady can clutch, downshift, blip the throttle, hit both brakes, lean, turn, and turn on a turn signal at about the same time without falling over.
Old May 15, 2014 | 08:13 PM
fourhour's Avatar
fourhour
Thanks for your responses. I have a couple options now. Don't think removing it is one of them, thanks for the suggestion.
Old May 15, 2014 | 08:36 PM
24v's Avatar
24v
Originally Posted by Warp Factor
Those of you who go without a horn can decide your own fate, just like you can decide to bungee jump without the bungee.
I prefer to think of it like having sex without a condom.
Old May 15, 2014 | 08:54 PM
Danny D's Avatar
Danny D
  • Nada! NO horn. Beep beep. Really?
Old May 15, 2014 | 09:01 PM
ghoticov's Avatar
ghoticov
I have my horn located between the down tubes. But the only reason it is there is so I can beep at a riding buddy to tell him he is going the wrong way. Lol
Old May 15, 2014 | 11:52 PM
Midgard's Avatar
Midgard
So where do you draw the line?
Always wear full leathers, always where a full face helmet, never go above the speed limit, never split lanes, .....................never ride a bike, only drive a Volvo etc...
Not being a dick just saying we can "split hairs on safety" all day long.
Bottom line we all ride motorcycles and put ourselves at a higher risk than others.
Old May 16, 2014 | 04:55 AM
Village Idiot™'s Avatar
Village Idiot™
Some states may require a horn for inspection. That or find a shop that just doesn't care.
I figure it's easy enough to relocate.
Old May 16, 2014 | 05:45 AM
Warp Factor
Fourhour, a lot of people mount the horn to the tab at the top of downtubes. The Rocker and Breakout come stock that way. I wouldn't just bolt those horns and brackets on though, they sound pretty anemic.
Looks like DK Customs has some good options (post #8).
If you get the Wolo air horn, cover it with a plastic bag if you're going to use a pressure washer. I didn't once, and it sounded like a frog for several days.
Also, if the work of wiring in the relay is standing between you and the Wolo air horn, it will work fine without it, at least on the pre"bus" bikes. A number of us are using it without the relay, and I haven't heard of anyone frying the handlebar switch yet.
Old May 16, 2014 | 10:24 AM
ADRENALINE RUSH's Avatar
ADRENALINE RUSH
i have been thinking about removing or relocating mine. if i can find a good place to put it or a smaller horn to fit somewhere nicely i would like to keep it, but i think the easiest and cleanest way is to just remove it.
ADRENALINE RUSH
most people i know don't get their bikes "inspected"... i inspect my bike on a regular basis better than most "state inspection" shops around me do. i've been riding for 10 years and have owned about a dozen or more street bikes, they all had proper registration, but none had current state inspection, it has never been an issue or even mentioned by police...
